Fender Paint Repair
Holland, MI, USA
Does anybody have any recommendations or advice on paint repair around the rear wheel wells. I know I'll need sanding, priming, painting, and clear coat, but is there anything else? This won't be a perfect repair, but I'm hoping to at least slow down the rust spread.
The drivers side is much worse because the inner fender is separating, so it might be difficult to fully repair that considering I don't own a welder. The paint bubbling underneath the fender protection is also worrying.
PXL_20250709_171524960.jpg PXL_20250709_171443779.jpg PXL_20250709_171453565.jpg PXL_20250709_171512117.jpg PXL_20250709_171440631.jpg
Dearborn, MI
The mark of the FiST! You pretty much have the idea as long as you can all the rust gone and still have enough metal to build up filler. If you do end up through the metal there's always fiberglass to build back up, usually from the backside. There's no way around body work sucking, being prepared for the suck is the only way to make it not a nightmare for me.
Central CT
Use a spray rust remover and then a metal/ wire brush before sanding it down. It will make the sanding a bit easier.
