PumaSpeed X-47 Hybrid Turbo Thread
How many have purchased / installed / tuned the x-47 Hybrid Turbo?
  • X-47 Purchased
    Votes: 53 74.6%
  • X-47 Installed
    Votes: 18 25.4%
  • X-47 Tuned
    Votes: 12 16.9%
  • X-47 Dyno / V-Dyno Results
    Votes: 8 11.3%
  • Total voters
    71
Calgary
Given our altitude, i expect a little more lag than most. It's also a lot cooler though, so maybe we'll make up for it a bit on the top end.
Calgary
Air at higher altitudes gets thinner, and thus contains less oxygen. So for the same volume of air, you will be compressing less oxygen than at sea level.
DHM1
Royal Oak
91oct+E30+Meth(50/50mix) Next couple weeks I will be hitting a real dyno. Will see how accurate these vdynos really are lol
3 fuel tunes.
What do you run for wmi? Also what size jet? It should be a richer afr than it is. It's not my place but I see room for improvement.
Russ
BoostBumps
BoostBumps
Arizona
Thread Starter #307
Ish's PumaSpeed x-47 Hybrid Turbo Results: E30 (91ACN) + Meth (50/50)
FORUM NAME: Ish
TURBO: PumaSpeed x-47
ADDITIONAL UPGRADES: Injen Intake, 2j-Racing DP, MBRP Cat-back, Mishimoto J-Line FMIC, Turbosmart IWG, GFB DV+
FUEL: e30 (91ACN) + meth (50/50)
DYNO OR V-DYNO: V-Dyno
TUNER: Tune +
RESULTS : 311whp / 313wtq (3 runs averaged) - 316whp (max)
Results above added to 1st page of thread...
http://www.fiestastforum.com/forum/threads/11791-PumaSpeed-X-47-Hybrid-Turbo-Thread
Sourskittle
Lakeland
Russ
I was thinking the samething ( not that I know anything about wmi ), but I was going to "let god sort'em out" since my help is insulting to some...
Ish
Coachella
Russ
Im running that boost juice 50/50 mix. Started out with a 500cc jet and ended up with a 1000cc.
DHM1
Royal Oak
Do your self a favor and get a can a VP M1 and distilled water. Mix it 50/50. It's $40 dollar cheaper than boost juice and it's works 1000000x better. Also it's actual methanol not glorified washer fluid. With this mix at 375whp we keep afr 11.9-12.2
Just trying to help.
Russ
Ish
Coachella
Russ
I was told the same from Stephen, just couldnt find a place locally that sells VP Methanol. I paid half price for the boost juice so it aint a big deal. Maybe once im out ill try ordering some VP meth online.
BoostBumps
BoostBumps
Arizona
Thread Starter #319
Looks like the closest VP Store / Retailer is either Temecula or Corona??
https://vpracingfuels.com/find-a-dealer/
