OEM ST badges
Hey guys,
I acquired my 2015 fiesta last year. For some reason the previous owner had removed both the front and rear ST badges completely from the car. I don't mind the badgeless look in the rear, but the front grill now has the empty spot outlining where the ST badge should be.
I have tried to locate an OEM ford diagram to track down the front badge, but I can't. Does anyone know where I can pick one of these up?
Thanks in advance!
-Aaron
MKVIIST
Send [MENTION=5890]Steve@Tasca[/MENTION] a PM, he may able to get the part for you.
John9851
I have the front and rear OEM ST badges available. I pulled them off my 2016. You will need adhesive to put them back on.
Zormecteon
If you don't want to contact Steve at TASCA, go a body shop. They know how to order that stuff.
A
Price is reasonable as is. In all honesty, with the tons of google searching for badges either OEM or aftermarket, I am surprised I never ran across his store.
Steve@Tasca
Vendor
Hey guys,
Thanks in advance!
-Aaron
We have both in stock, use code 2016tasca if you order.
Front, http://www.tascaparts.com/oe-ford/cm5z5842528b
Rear, http://www.tascaparts.com/oe-ford/c1bz9942528a
-Steve
neeqness
Thanks! Do you know if these come with adhesive?
Look at the description. The one I picked on says:
Velossatech Website said:
Product Description
Rear ?ST? emblem for your 2013-2016 Focus ST or Fiesta ST. Replace that tacky stock emblem with something clean.
Comes with 3M automotive grade double sided tape, just peel and install.
neeqness
Cool thanks! I've been looking for a black rear ST emblem. The oem red ST emblem is almost completely hidden on the race red ST and the black goes well with my red/black theme.
Sent using Tapatalk
CanadianGuy
Sent using Tapatalk
Why not use some vinyl?
CanadianGuy
That looks cool. Did you make it yourself?
Sent using Tapatalk
Yes. Overlaid a piece of vinyl and used a razor blade to cut the outline following the inside edge. Very inexpensive if you know someone that does vinyl wrap you can get their scrap or of ebay and want not lots of people sell short piece very cheap.
