- Member ID
- #3665
- Messages
- 231
- Likes
- 135
Unless you can speak to a Ford engineer that worked on the FiST program, I doubt we'll ever 100% know for sure. All we have are theories. CP-E just released an adapter that doesn't block it off, so that's an untested option for anyone that's interested. Hopefully they have better luck than MAP or Mishi.
I'm not advocating for or against this method. I can only speak for myself, but I've put over 20k miles with it blocked off with zero issues.
It basically boils down to a simple question: Do you have a 2016+ and want to run an aftermarket intake without throwing a CEL? Currently, blocking it off is the only proven method that doesn't throw a CEL, so this is your only recourse unless CP-E's adapter pans out or MAP/Mishi fix their designs.
Your other option is to just stay stock. The stock intake is very well designed, and a good drop in panel filter and maybe a VT Bigmouth will pretty much net you the same amount of HP as most any aftermarket intake, with maybe the exception of the 2j. Aftermarket intakes on this car are basically engine bling that makes whooshy noises. Even my MAP intake still utilizes the stock plastic crossover tube. So why didn't I just stay stock? Because I wanted engine bling and whooshy noises, and the money was available.
![Smile [:)] [:)]](/images/smilies/smile.png)
