Brake pad options(large collective list)
So, after a search here it seems that there wasn't a good collected reference of most/all of our brake pad choices. On other forums I've been on had this and thought it would act as a good living document for the members to see what's all out there and make an informed decision on pads for our cars.
Each manufacturer listed had the part numbers on their site, and they are copied here. I chose not to post prices, as they will vary based on who you choose to buy from and I didn't want to step on vendor toes if any wanted to offer discounts/group buys in the future.
As an added note, if you find something that's not listed here, PLEASE message me, and I'll try to seek out the info and add it to the list here. I made this to be a good reference, and I think I covered most of the common stuff, but there's bound to be options I didn't find/ overlooked in my postings.
Also, I didn't include the factory pads, as those are a known entity at the dealerships...
now, to the list....
Fiesta ST Pad Options
Front Pads Rear Pads
Hawk Performance
HPS 5.0 - HB725B.650 HB430B.547
DTC-60(fr only) HB725G.650
HPS-Race(fr only) HB725R.650
DTC-30 HB725W.650 HB430W.547
PC(performance ceramic) HB725Z.650 HB430Z.547
HPS(rr only) HB430F.547
HP-Plus(rr only) HB430N.547
HT-10(rr only) HB430S.547
Blue 9012(rr only) HB430E.547
Powerstop
Z16 16-1730 16-886
Z17 17-1730 17-886
Z23 Z23-1730 Z23-886
PM18(rr only) PM18-886
Carbotech
(compounds are all available for both axles, and no specific PNs are given)
1521
AX6
XP8
XP10
XP12
XP20
XP24
RP2
Akebono
Ceramic(rr only) ACT886
Centric
Posi-Quiet(metallic) 104.17300 104.08860
Posi-Quiet(ceramic) 105.17300 105.08860
Stop-Tech
Street(rr only) 308.08860
Sport(rr only) 309.08860
Mountune
RS-R(road) 7064-BPF-B1 7064-BPR-A1
RS-T(track) 7064-BPF-B2 7064-BPR-A2
EBC
Greenstuff DP22149 DP21218
Redstuff DP32149C DP31218C
Ultimax2 UD1730 UD886
Yellowstuff DP42149R DP41218R
Ferodo
DS2500 FCP4612 FCP1319
Mintex Pads F: MDB3322 R: MDB1959
M1144 (DS2500 equivalent) MDB3322M1144 MDB1959M1144
3322 F4R comp compound 3322F4R16.75
A
Thread Starter #2
HAWK pad descriptions
CODE COMPOUND OPTIMAL RANGE MIN MAX TORQUE
R STREET RACE 100?-800? 100? 1200? MEDIUM
Designed to and from the track without requiring a brake pad change
Wide temp range
Controllable torque
Smooth feel and bite
N HP+ 100?-600? 100?-800? LOW
High initial bite
Designed for pavement circle track under 2800 lbs
Designed for applications not needing high deceleration rates
B HPS 5.0 100?- 550? 100?- 750? LOW
Increased stopping power compared to HPS
Gentle on rotors
Smooth and predictable torque
Virtually noise free
F HPS 100?- 500? 100?- 700? LOW
High friction/ torque hot or cold
Gentle on rotors
Provides consistent and controllable torque through temperature ranges compared to stock pads
Z CERAMIC 100?- 450? 100?- 650? LOW
Gentle on rotors
Low dust output
U DTC-70 800?-1200? 400? 1600? HIGH
Designed for high deceleration rates
High temperature fade resistance
Very low abrasive rotor wear
G DTC-60 700?-1100? 400? 1600 HIGH
Slightly lower torque than DTC 70
Recommended for use with DTC 70 when split friction between front and rear axle is desired
Similar but lower torque profile as DTC 70
V DTC-50 500?-1100? 300? 1400? HIGH
Designed for high deleration rates
High temperature brake fade resistance
Very high torque with aggressive initial bite
W DTC-30 100?-800? 100? 1200? MEDIUM
Wide Optimal temperature range
Smooth feel with good initial bite
Good cold effectiveness
A DTC-15 300?-600? 200? 800? MEDIUM
H DTC-05 100?-500? 100? 700? LOW
Designed for use in Dirt Track racing
Controllable, higher-temperature perfomance.
L MT-4 500?-1000? 400? 1200? HIGH
High initial bite
MB METALLIC 200?-1300? 100? 1700? HIGH
Specifically designed for ceramic coated rotors
M BLACK 200?-700? 100? 900? MEDIUM
Medium torque and temperature pad
A good all-purpose low-cost racing brake pad
Good for Dirt Modified and IMCA style pavement Modified
A small sidenote with Hawk compounds. If you call them, they can get you any compound they make on your pad shape(even if it's not listed). Usually what's listed is the common applications or what they feel is the most applicable pads for each pad shape.
A
reserved for pad compound descriptions
A
reserved for pad compound descriptions.
KKaWing
Mintex Pads
F: MDB3322 / R: MDB1959
M1144 (DS2500 equivalent) would be Front: MDB3322M1144 / Rear: MDB1959M1144
3322 F4R competition compound - Front: 3322F4R16.75
I really liked my EBC yellowstuff at the track, held up very well 0 fade and great stopped performance (vehicle weight around 3000 w/2 people in it) stoptech slotted rotors (both front and rear)
I really liked those ebc yellowstuff pads too!
For the sake of future reference, because this is a great OP, the EBC Redstuff pads are seemingly not available any more for Fiestas, at least in the UK/Europe. I've tried ordering from multiple retailers - and even direct from EBC's own web shop - and they are simply not listed as an available part.
The best I could achieve was Redstuff rear pads from Andrew Page, no front pads available - that's probably just because their supplier has some old stock. I guess they weren't a popular enough fitment size to make it worth manufacturing the pads for Fiestas.
shoot [MENTION=5976]ron@whoosh[/MENTION] a pm
https://whoosh-motorsports.myshopif...llowstuff-front-rear-brake-pads-free-shipping
