meth on stock turbo questions!!!
hey guys, trying to find info on installing a meth kit with stock turbo, all i find is with upgrated turbo set up, somebody has meth on stock turbo, what are the numbers you guys getting? i have cai, lightweight flywheel, full exhaust, j-line intercooler catless downpipe so far on stock tune... thinking getting meth injection before going to dyno tune. would it be woth it? thanks for the onfo guys
Brura22
Yes, meth will boost any turbos HP.
You'll get 20-30 hp with a protune
rastok
Really? On stock turbo?
rastok
Any more torque? Where would the gain low/mid/high?
Brura22
Turbos don't matter with meth.
You're literally spraying alcohol into your engine.
Regardless if it's a 6.0 v8 or a 1.0 motorcycle.
You're going to be able to pull more timing and make more horsepower.
Higher octane = more aggressive tuning. Same on any internal combustion engine.
That's why water meth can be used on any motor with benefits.
rastok
Nice info! Thanks man!
rastok
Did someone actually did this?
rastok
How did it felt? Did you had it with stock tune?
Brura22
You won't gain any power on water meth without a protune for it.
You gain power by advancing timing and increasing boost. Which water meth allows you to do safely.
Running it on a stock tune is fine, but you won't gain power.. just lower charge temps and clean valves lol
rastok
I thought with direct injection the engine could advance timming on its own regarding of the inlet temp.
Brura22
Yes it will, but you're not gonna gain noticeable power without a real tune
rastok
How do you like the snow stage 2? Would you go stage 3 if you
Could? How hard is it to make it work properly and to tune? Thanks for all the info btw i appreciate it!
Brura22
I don't tune myself.
I have a lifetime protune from Adam at Tune+
Stage 3 is unnecessary. The stage 2 VC-50 is the best.
I'm an aircraft mechanic by trade, so hooking up 4 wires and a boost line was simple for me.
rastok
Did you sail safe?
