OK, thanks, just wanted an another opinion because kansei on here could not tolerate the sound pressure of this system without the resonator, at all, and reinstalled his cp-e resonator after trying it without.
 Mitch @ CPE and I have had conversations and I have spoken with another guy at Garrett about the exhaust situation. The problem here is if your going to make 300 you need 3". This is a hard rule that has always appliedand is clearly documented on about 100,000 websites both technical and by experience. When using a turbo, it is all about unrestricted zero backpressure exhaust. Over 350 the rule says the bigger the better. While there are some here making close to 300 and 300 on the stock size exhaust you are leaving power on the table. With that said, the resonator does nothing for the loudness of the exhaust All it does is change the tone. I have much experience with the exhaust on this car. I have had 4 various types of exhaust systems both catted and catless. I have changed the resonator on the CPE to a longer smaller diameter and it did make a difference and it changed the tone, but nothing I have done under the car, ever changed the loudness of the exhaust. It only moved the tone in the frequency range. I am using a Audio Control RTA to measure the changes. If you want to control the loudness of the exhaust it has to be done at the tailpipe. The only options here are straight through mufflers, if you dont want to give up power.
Mitch has mentioned some options.
The goal of an exhaust for this car in a modified stated should be
The goal should be to remove the drone from 3K to 5K under moderate driving. under WOT who cares.
The goal should be to remove or greatly reduce the noise at startup, and low RPM and low MPH driving
If I am cruising at 60-80mph, Remember where i live, in Idaho (right down the road), it is 80MPH and the same heading towards Seattle in I-90. I am in Spokane WA. I should not hear the exhaust, You are close to that now at 60, but at 70-80 the exhaust note is too loud to have a normal conversation in the car.
Mitch responded with the following
So we have a few options:
-Adjustable helmholtz resonator. (see CP-E Focus ST Exhaust)
-Dual exit- The more I think about it, im not sure how well this will do at cutting sound by itself. Space is really tight with the spare tire well so adding a muffler or resonator might be a stretch
-Boost Actuated Valve- This can pair up with dual exit. Have the second exit have a boost actuated valve. Theoretically, the closed valve will act as a second helmholtz resonator to bounce back sound waves when not under boost.
-Second helmholtz resonator Cobb Style (Cobb 135i exhaust)- more space efficient.
-Adding a "race muffler" between the stealth pipe and the tips such as this one
At this point I am not willing to give up my straight through exhaust as I am not willing to sacrifice any power. So I will be examining these options and should I make a profound discovery i will share my findings.
For the haters, yeah I know, its a high hp 4 cylinder. I have no car, no muffler, its going to be loud. I get all that, however and but, it doesnt mean I cant try to find a solution to drop the volume some under specific conditions.
