Mountune RMM creaking
Stafford
I had the dealer install the mount today and after about 4 hours of running around after, it developed a creaking sound when starting from a stop. Is this normal and will it stop?
Prince George, BC, Canada
No this is not normal, I've installed two of these kits from mountune and never experienced any creaking sounds. From what I've read from other posts is that if the main bolt for the RMM isn't torqued properly then it may cause these issues. I think the torque spec is 65ft-lbs but the instructions should also list this too.
dooku77
Stafford
Thank you. I'll have to bring it back to where I had it don't on Monday.
dooku77
Stafford
it might be the plate as well. Have them look at it but another common solution is a dab of silicon grease to the bushing.
This is what I've been reading. I'm going to call them on Monday to make an appointment. I was just worried about damage. Seems it's just the properties of polyurethane bushings it seems.
QC
Mine did this for maybe 3k then stopped.
Seemed worst when it was hot outside.
dooku77
Stafford
It seems to happen now only after a long trip or if I reverse and then go forward again.
