Thread Starter
- Member ID
- #5638
- Messages
- 4,001
- Likes
- 4,111
Thread Starter
Ok, got my mount in the mail this morning, and installed it right after work. First, the package shipped direct from AWR (ordered through Whoosh) which is legit, no middle-man BS or delay in shipping. Install was much easier than I thought, and not including the time it took to jack the car up onto jack stands and remove the wheels (was doing brakes and oil as well), it only took maybe 20 minutes to remove the stock RMM and install the AWR mount. All you need for install (besides jack and stands or ramps) is a ratchet, 13mm socket (deep well preferred), and an extension, but you could get by without an extension. Only six bolts needed to be undone, then you drop the factory RMM and bracket, and replace it with the new one. There are many videos on this, just use the Google or You Tube and you'll be good to go. It really is much easier than I thought it would be going into the swap.
After starting it up, I honestly forgot that I had installed it (did oil last) and was listening for any weird noises that would indicate a botched oil job (like leaving the drain plug out, had a buddy do that), and kind of freaked out because the car seemed to idle rough. Like I said, I freaked out a bit, all for about 1/10 seconds until I realized what else I had done and was good to go from there. I installed the 88A durometer version. There are definitely more vibrations at idle and while taking off (anything under 1500rpm), but it isn't significant at all. If you have an exhaust that's any louder than stock at idle, you likely wouldn't notice too much anyways. This is one of those things you have to realize when buying an RMM though. If you think the vibrations will bother you, get the softer version which will still be a vast improvement over stock and much better than the version I ordered. Hard launches and shifting feel much better now, no more clunk when shifting from 1-2.
