- Member ID
- #4806
- Messages
- 500
- Likes
- 137
Hey guys, I installed an oil cooler a while back, and despite wrapping the braided lines where they may come in contact with any lines, my braided lines rubbed a small pinhole in one of my AC hardlines at my last trackday at Thunderhill. I got to drive home in 107 degree heat :'(
I attempted to fix the pinhole with some JB Weld. I recharged the system, but it seems to be spewing back out of that hole. I've tried to seal it again with JB weld and no luck. I've now wasted one can of r134a.
So now I come to you guys. Is it best to replace the part: I believe its 19D734A- the hardline/softline with the low pressure port. The pinhole is located just below the can looking object at the bend.
I've attached the OEM part diagram, the purple box is approximately where the pinhole is located. I believe this is the right diagram, the part is question is the AC line with the low pressure port that has the rubber covered line going down into the engine bay, right next to the coolant expansion tank.
Or is there another trick to sealing that pinhole which is now covered in JB weld.
Is anyone experienced with replacing AC lines? I'm guessing I should make sure the whole system is bled before removing the hose. Does anyone know if I need new gaskets on both sides / any specific info I need to know when replacing it?
Any advice is well appreciated. Thanks!
