Hey all, I'm prepping for my next track day, and I've been messing with tire pressures, setups ect.
I'm trying to reduce understeer, and promote the tendency of lift off oversteer, and oversteer in general. Being a FWD car, it will never be as oversteer happy as some of my Front engine, rear wheel drive competitors. I find my biggest issue is with long very high speed sweepers. 80-90mph sweepers I find the car wants to run wide, and I have to dab some brake, or lift off the throttle to get the car to turn in. In a long right hand sweeper, I can feel all the weight load up on the front left tire. Besides more seat time, what is the next "Must have" handling mod to get the most out of the car? My signature is up to date with all my mods. Would like to know what your advice is!
Sway bar? Pierce bracing? I can't afford coilovers at this time, as I'd rather spend it on track time. I'm interested in any suggestions, but what will be the most bang for my buck?
The car in track trim has everything behind the driver seat removed, no rear sets, no rear flooring ect. Also I do have a race seat up front reducing some front weight. However, with the Mishi rad, my oil cooler, and the bigger intercooler it puts more weight up front. I will be running Federal RS-RR 215/40/17's for my Laguna day. Hot pressures that I'm going to start on is 36 front, 34 rear and go from there. With the extra weight up front, I wonder if I should raise the front pressures by 1 more PSI to make up for weight. If anyone has pressure ideas I'm open, I've played around with pressures a bit up and down a few psi and this seems to run the best on my last tires.
