[MENTION=1015]shouldbeasy[/MENTION] How did you verify that you got the right part? I'm seeing a a few parts when I search, but I'm worried that I may end up getting the physical controls. Did you [SCAMMER ALERT] beforehand?
There are no "wrong parts" so long as you know what the donor car is - so, it's best to ask for the VIN. The most economical way is to source the screen and the APIM module from a junk yard. They should show the year and the VIN. But yeah - describe what you want, you will likely need to do it anyways, none of them are equipped to sell online, you'll have to call, as the inventory is also not likely to be current either...
You can supposedly get the combo from another Ford vehicle, but then you'll have to mess with the brackets and will definitely have to flash your as-built file.
None of it is worth the effort - so, keep looking for a 2016+ FiST; they are not too common, but do pop up from time to time.
I ended up with a NAV unit, which I didn't really need because of the AA. $350 all in.
Sent from my Pixel XL using Tapatalk
