Fiesta Handling Pack - M-FR3-FA
brbauer2
I've had this suspension in the garage for several years since I originally bought it for my '14 SE but never installed it.
Is anyone running it on their FiST? I know there is going to be very minimal drop, just wondering if it's worth the install for ride quality/suspension response.
https://performanceparts.ford.com/part/M-FR3-FA
Could that just be the actual factory FiST suspension system marketed as an upgrade for the 'lesser' Fiestas? [dunno]
I had it on my first SES, the Fiesta handling kit was the oem kit from the EU market standard Fiesta. It isn't ST related. It was a huge improvement over the standard suspension but would be a step down from oem ST parts.
Thanks for clarifying this. [thumb]
Basically, slightly less spring rate/lowering and damper valving than the factory FiST setup?
It's a 10mm drop from standard Fiesta vs 15mm for ST. Lower spring and damper rates also.
BRGT350
Yep, this is exactly correct. I ran the same setup on my 2011 Fiesta.
brbauer2
brbauer2
Thanks for all the info!
Guess I'll just keep mine as a backup and go with a different setup in the spring before I start tracking the car.
Sent from my ONEPLUS A3000 using Tapatalk
