Pro Alloy coolant tank installed - pics and install impressions
ron@whoosh
Vendor
Las Vegas
I had a chance to install one of our Pro Alloy tanks tonight.
This tank has the outside dimensions of the stock tank, maybe slightly smaller. It literally fits perfectly and well, take a look at the pictures...the craftsmanship speaks for itself...
This is one amazing piece
The sight glass is a must have in my opinion.
When installed, I just removed the passenger side headlight. Used a modded half gallon milk container (left the handle intact / don't laugh)
Didn't spill but a few drops this way.
One thing I changed was removing the OEM spring clamp from the lower hose and replaced it with a euro clamp instead. Cleaner and easier for me.
Enjoy the pics.
Link to product on the site>>> https://whoosh-motorsports.myshopify.com/collections/2014-2017-ford-fiesta-st/products/pro-alloy-2014-fiesta-st-alloy-header-coolant-tank-pending
I knew I had the 10k around for this rainy day gem!But it does look like a very tasty piece!
Gatineau
What are the advantages of having this instead of the stock tank, other than aesthetics?
Dallas
Back when Mishimoto was creating their tank, they got a lot of questions like this and some blow back. Basically, yes, it is an aesthetic piece, but a much more durable piece. Mishimoto stated that the plastic does deteriorate and becomes brittle. I can vouch for this plastic becoming brittle (past cars), at least where mounting points are concerned, but this is often after many years of use. Heat is a female dog! Given the cramped nature of the engine bay it is often necessary to remove/relocate the tank to open up areas more. Naturally, the more you mess with the plastic tank the more chances you have to brake it. Granted our tanks are not screwed down, which helps, but it is still secured in a way that it could crack if forced. Again, this might not happen until maybe 10 (give or take) a few years down the road. It is a very nice looking piece over the stock tank though.
KnockOff
Menifee
Yea the plastic on my old focus and my buddy's focus the tanks just cracked out of nowhere. I did find the newer style replacement for 25 bucks but that's beside the point.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
this is a great response - thank you
the Pro Alloy tank is bolted to both mounting points
the only other thing I would mention is when you have a race car, you do race car things.....[lovest]
Once my OEM plastic tank gets many miles and years on it, and therefore becomes much more likely to crack and leak, I will get one of these and probably paint it with the high heat VHT caliper satin black paint as to not jump out and appear conspicuous to a warranty dealership (IF I even still have a power train warranty by that time!).
My brother had to pay over $250.00 for a crappy, ill fitting, China made plastic tank for his POS Boxster, since the 'great/infallible' OEM Teuton made one cracked and leaked like a sieve, ruining the liner of his trunk area, and leaving a permanent stink of old, acidic, used coolant in that whole area of the car.
The actual German made OEM ones ran upwards of $600.00! [crazyeye]
ron@whoosh
ron@whoosh
Vendor
Las Vegas
no need to get you rattle cans out, they come in powder coated satin black
ron@whoosh
ron@whoosh
Vendor
Las Vegas
not everyone is on the forums folks...
here are some happy Pro Alloy customers
one powder coated his Pro Alloy tank with sight glass to match his other engine bay parts
and another has a satin black Pro Alloy tank because he didn't want the flashy polished look
ron@whoosh
ron@whoosh
Vendor
Las Vegas
NICE! [thumb]
Is the capacity the same as the factory tank (NOT that it matters, just curious ;) )?
I should know this
but I don't sadly....
I will tell you this, I didn't spill anything when I swapped mine over
After filling the Pro Alloy tank with everything drained from the OEM, the sight glass shows just a smidge over half way full which I thought was appropriate [like]
ron@whoosh
ron@whoosh
Vendor
Las Vegas
we have some polished tanks with sight glass in stock, ready to ship
Jabbit
New England
Any more info on this euro clamp? My factory spring clamp thing won't fit into the lower connection.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
I don't remember the size , this PA tank was installed almost 5 years ago
If you measure the hose OD , any worm gear clamp would work. I just prefer the norma torro style
Woods247
Atl
Bumping this old thread. Will this tank clear a Damond Catch Can?
