Shifter cables touching downpipe
DangerMouse
Illinois
Just installed a mountune downpipe and the shifter cables were touching the cat section. I bent the cable bracket upwards best I could to create clearance but it didn't do much.
Should I be concerned?
kivnul
U.S. Army Veteran
Deer Park, WA
I have an email out to mountuneusa about this exact issue. I took one cable out of the bracket to make a 1/8" clearance. I have some heat tape on route that I will put over the cables to protect them the best I can. Dunno what else we can do really.
DangerMouse
DangerMouse
Illinois
I'm definitely going to look into some heat tape now, good idea. Not much room down there and I think the cables were touching the heat shield on the oem downpipe. Mountune must have noticed something like this when they designed their downpipe, being that they went with such a large diameter cat over what everyone else uses.
North Branford
Did you guys recently receive these downpipes? I've been waiting for one that's been backordered since December.
DangerMouse
DangerMouse
Illinois
I bought mine used. I did see a few months ago I was going to buy new from mountune and it wasn't even on the website.
North Branford
Ah okay, thanks. Just trying to determine if this is something that they may have corrected or if its something wrong with the latest production run. Honestly I'm considering just selling this thing if it ever shows up. Exhaust interference with the shift cables is unacceptable. I've purchased a bunch of Mountune parts and really haven't been impressed with the fitment of any of them.
DangerMouse
DangerMouse
Illinois
I messed with it again today and I have a little more clearance, maybe 1/4", I'll keep an eye on them.
I wonder why I haven't heard about it before, I'm guessing it's not an issue, but I would rather be cautious than have issues.
kivnul
U.S. Army Veteran
Deer Park, WA
Glad you have been able to make room, I havn't taken a look at mine yet. Ill be under the car this weekend and will look again and shift/tape them up.
I also bought mine used (new in box) back in November or so. These downpipes have the largest cat (5") of any downpipe on the market. Clearance issues are to be expected tho it is weird that there is nobody saying anything about this in the past. It is possible that the routing of the cables has changed over the years so it could be hit or miss on who is affected.
DangerMouse
DangerMouse
Illinois
Kivnul, where did you get the heat tape? Is it something I can get locally or does it need to be ordered?
North Branford
I ordered this. Like I said, I have not used it yet. Reviews make it sound like it sticks on really well.
https://www.amazon.com/gp/product/B00029KC2A/
I've used a similar product in the past, I believe it was made by DEI. If its anything like the stuff I've used, yes it will stick quite well, and that's where it will be for eternity.
haste
Eastern
Can we get a pic of this possible issue? Top of the engine bay and from below? I am curious. I heatwrapped my downpipe but I don't remember anything coming close to touching it during/after the install.
I run catless CPE downpipe. May be a difference between catted and not catted? I don't have a comparison pic of my stock downpipe.
Is it the cables to the bottom right in the bracket?
Closest pic I can find from my archives is here:
DangerMouse
DangerMouse
Illinois
Yes those are the cables. You are fine with any brand even catted other than mountune. The cat is huge on mountune dp.
Fist pic is for orientation, both are from above but best I can do for now. Second pic shows more from the side.
https://imgur.com/a/Yd31s5r
kivnul
U.S. Army Veteran
Deer Park, WA
First pic is for orientation, both are from above but best I can do for now. Second pic shows more from the side.
I endorse these images. You did a better job of moving them than I have so far. It seems that the cables cross just before they exit the heat shield. It may be worthwhile to remove the shield temporarily to see if there is a better routing available.
DangerMouse
DangerMouse
Illinois
I got lucky, I used a super long screw driver to bend the bracket up a little and it's enough for now.
I'm super tired of being under the car or I would check out the cable routing and see if I could gain some more clearance.
I'm going to order some heat wrap or tape or something and check it out when it gets here.
