Decal removal problem
I decided to remove the dealer decal yesterday, and initially it went fine; got a plastic scraper and removed all the lettering, then used gunk off, (Or goo off, I don’t remember which one), to remove the adhesive. It seemed to clean the spaces where the letters were, but it made a kind of a sticky mess all around it. I think the problem is that I had waxed it about a week ago, and the combination of the gunk off and some probably too vigorous rubbing disturbed the wax. It was only then I realized I should have removed the decal before I waxed it. I guess now I need to remove the wax in the area I cleaned and re-wax it. Any suggestions? Thanks
Yeah +1 on the 3M product, it's good at removal without being destructive to the paint.
I had this other stuff called ARDX51 but I cant find it anymore....really pricey like $40 qt pricey.
This is also fantastic shit..... hard to find.... by genesis coatings
alexrex20
Can of Brakleen or some Seafoam on a rag always works for me.
Believe it or Don't! But Good old Wd-40 also works well! cheap too! There's like 1000's of uses fo that stuff...crazy! [party]
cxwrench
WD works really well!
You're slacking...3 replies to this thread and NO gif's?!? [confuse]
Gotta be careful with Brakleen that stuff will remove paint if you use to much or rub to hard. It will take clear coat right off. I bet Seafoam will do simular.
B
WD-40 to the rescue! Thanks for the tip, guys. No just have to a spot wax where the letters were.
To the OP... is this the 'goo' remover that he used? Or has anyone else used it, with good results? BTW, looking for a solvent to remove/clean off the 'Fiesta' emblem in the back.
B
Thread Starter #18
That’s what I used. Can't say if I recommend or not. The decal came off easily with a plastic scraper, but left a sticky film. WD40 took the film right off, though.
HBEcoBeaST
Do it in the sun or warm up the area. 10x easier.
Wd40 is best. Clay bar will work too.
Brendon
I found the Goo Gone and simply rubbing with my finger and removing the balls of gunk with a paper towel worked well for the deal sticker.
