Sealed box intake to work with Velossa Tech big mouth.
I know the stock intake is probably fine. I think I'll just get a drop in filter but I was wondering if anyone used a different intake with the Velossa Tech big mouth. Pretty much going for more spinny woooosh noises.
felopr
it shouldn't really matter what you use for intake, the velossa tech big mounth doesn't connect to the intake box directly, it connects to the front of the car directly
D
Pretty sure I pressed it in to the intake tract when I did the install
felopr
no, you press it on a open slot in the radiator support.
you can remove all of the intake box all by itself
He is talking about the inlet to the box that runs over the radiator core support.....and I just said what you did! FML! [party]
D
Correct. It does feed the box, providing less restriction when at speed.
XanRules
As others have stated, it feeds into the stock airbox. It would be redundant with boxes such as the CPE, Mountune, and ST200 as they pull cold air from outside the car as well. Might make a difference with the Cobb intake, might not.
