Which hub kit did you use for that; Sparco, Personal, OMP, whatever (can't read the logo) steering wheel?
You gutted a bit more than I did (I left in the rear plastic side panels, and front console/arm rest box), but everything else is gone (rear belts, seat assembly, etc.).
Hi RubenZZZ!...To get various colors (Basically I've got 4 colors, red, blue, purple and green), there is an easier way compared to swap all rear leds..
I use colored transparent plastic, sticked in the rear part of the black instrumentation panel.
I've to disassemble the instrumentation every time I want to change color...But basically it's quite easy to do this kind of operation ..
I've used OMP hub kit.
The picture is too dark to see it. I'll post many others, in a brighter way
Yeaah!...I've gutted lot of things ..In my garage there are 3 big cartons full of plastic parts and pieces of the FiST…(The total weight is about 330 lbs)….But I think I'll use my FiST only in Tracks...
The shifter is the stock one..You can see it displacing the leather cover
The stock color is black..I've only used an alloy paint for plastics
To obtain the final result, must delete the central tunnel:
