we promised a big brake kit....stop in and take a look :)
LilPartyBox
NYC
#61
When it comes time to replace the rotors, will we be able to order the rings without the hats as stoptech and other companies do?
Also, will there be any kind of warranty for this kit?
Perfblue15
Canyon country
#62
Nice kit. This looks like a great budget BBK for thos wanting to fill out their rims more. I've ridden in a car with the gold coast bbk which is a great budget BBK as well. The Porsche caliper option looks like a cool budget alternative to the Wilwood kit as well. I'm interest to see how that pans out.
I'm personally interested in a kit Using 4 pots that will clear 15 inch TDR wheels. I may end up having to make something myself as what I want is super Niche'.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #65
This is interesting
See below for 325mm 2 piece rotor weight
Someone please chime in about the OEM front rotor weight - I've read 14.5 lbs but I do not know that for certain
Also to correct an earlier post made about the rotor hats - the coating is anodize, NOT powder coating
Sekred
Mid North Coast
#69
I like this brake kit. Its good that people are putting in the R&D to develop more options for this platform. R&D is basically unpaid and it takes time to get your money back.
What I would like to see is BBK that will fit behind a 16" rim. I don't think this kit will fit with a 325mm rotor. My estimation would be around a 315mm maximum rotor diameter depending on the caliper.
alexrex20
Spring
#70
My Wilwood BBK fits behind 16 in wheels. I wouldn't be surprised if this kit fits behind 16s also because the OEM caliper is very low profile in terms of diameter.
Sekred
Mid North Coast
#72
The Wilwood rotor is around 310mm
alexrex20
Spring
#73
That is an overall diameter difference of 15 mm. So only about 7.5 mm difference in terms of wheel clearance. I have more clearance than that between my caliper and wheell. And because the OEM caliper is much lower profile, I will bet money that this whoosh kit clears 16-inch wheels.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #74
I agree
this looks like a 3 lbs per side weight savings going to this 325mm rotor as well. I'll have to weigh the bracket and half the attachment hardware to find the actual weight savings per side
Josh Jackson weighed his new OEM size front PowerStop slotted rotors which are 15lbs each
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #75
kit should be fitted in a few days
install pics and review will be available + our tester has 15" TD wheels so we will know if clearance is an issue or not after installed
stay tuned
LilPartyBox
NYC
#76
Maybe I'll get an answer 2nd time around?
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #77
If you mean about warranty, I have no idea at this point. We are in the fitment / testing stage
I can assure fitment and working as described 100% but rotor warping and things like that are tough to answer at this point. I'd like to get past fitting, wheel size confirmations, and some testing before that discussion is finalized
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #78
I'm excited to hear more about fitment. It would be great if this will fit on some 15" wheels as that is my preferred size for winter tires.
I hope 15's fit as well
The rotors are just amazing but HUGE!
We will know this week[thumb]
LilPartyBox
NYC
#79
Thanks for the response.
I was also concerned about the availability replacement rings....
