Jo's track Fiesta ST180
Urspelt
Hello, I'm Jo from Luxembourg. Since 2014, I did about 60 laps on the Nordschleife with my ST. In November 2015, I started to rebuild my daily car to a proper track car.
After striping the whole interior, first I wasn't sure if I should build in a bolted or a welded 6 point cage. I decided to build in a welded 6 point cage (25CrMo4 steel) from STAHLUS Rennsportzellen in Germany. Mid 2015, I got my car back and started rebuilding the car step by step on my own.
After a long way, with many setbacks and detours, the car is nearly ready for its first rollout. But there is still a lot to do until the car is completely finished and road legal.
Spec:
Interior:
- 6 point welded cage (25CrMo4 steel)
- interior painted in RAL 9007
- CORBEAU Pro Series seats
- SCHROTH Profi III ASM harness
- Carbon driver footrest
- Steel passenger footrest
- M-SPORT door cards (Fiesta R2T)
- flocked dashboard (still to do)
- AIM MXS 1.2 Strada Dashboard (still to do)
Outside:
- ST XTA suspension is going to replaced by a KW Competition 3way on FA and 2way an RA
- DREXLER plated diff
- standard brakes with braided lines, Endless brake pads, self build brake cooling and Castrol RBF racing brake fluid
- in step 2: AP Racing calipers with 295x28mm discs
- poly windows
- underfloor protection removed an underfloor repainted
- ATS DTC 7x15inch wheels with Nankang AR1 205/50 r15 tires
Engine:
- Airtec stage 2 intercooler
- ITG air intake an crossover pipe
- 12 row Setrab oil cooler
- Mountune MP215 software at the moment
In a second step:
- new turbo with 200cell sport cat, custom exhaust
- rewiring with new ECU
- dry sump kit
Sick build!! [twothumb]
That has to be THE most extensive (and gusseted/triangulated) 6 point cage I've ever seen!
I am guessing that your country's road going regulations are NOT as outright draconian as Germany's TUV, since your build could never be 'street legal' in that country? [dunno]
L
Urspelt
If I was part of the Royal Family, why does it take more than 3 years to get the car ready? [wink] no I'm NOT part of the royal family. Nearly everything in the car has TÜV papers or ABE/ECE numbers on it. Standard steering wheel is going back into the car because the race steering wheel is not allowed
Too bad there is not a super-quick way to swap between the race wheel/hub assembly, and the factory whoopee cushion equipped wheel, for track day use (or does the law require it even there? [dunno]).
L
Urspelt
It depends on the event. But I'm not goong to change it every time. So I'll go an let it re-trim in alcantara with 12 o'clock mark
NICE!! [twothumb] [driving]
If I do not dump the exploding killer cushion factory wheel for an aftermarket Sparco/Personal one, I want to do the same thing. ;)
Are non-factory, airbag-less, aftermarket seats (whether one piece, racing shell type, or racing style recliners) street/TUV legal there, or not? [dunno]
L
Urspelt
Like I said, Recaro Pole Position ABE seats have ABE (Allgemeinen Betriebserlaubnis), SCHROTH Profi III harnesses have ECE papers --> street legal. Airbags are required for steering wheel and dashboad.
Welded cage is also possible to get it road legal. I don't know if you have ever been at Nürburgring but there are plenty of road legal race car [rockon] You only need a good TÜV expert.
That IS cool that they allow non-airbag, one piece shell seats, and cages, on the streets, given how 'Gestapo/Stasi' the TUV can be. ;) [cool] [thumb]
Are some of the race shells street legal, even without a cage/bar, and backbrace, backing them up (stand alone, using just factory 3 point belts)? [dunno]
L
Urspelt
I'm not a TÜV expert. I don't even understand what you mean with "race shell" which doesn't have a cage/bar, etc. [???:)] [biggrin]
I define a "race shell" as any ONE PIECE, NON-reclining, NOT factory supplied, excessively bolstered/'winged', fiberglass, carbon/kevlar, or some other composite thereof (or even steel tube framed, but not reclining) deep seating position seat, whether FIA approved for competition, or not, or 'halo containment' equipped or not. ;)
Some sanctioning bodies/run groups here in the states will not allow you to go out on track with these in a car without at least a roll bar with a supported back brace attached to the seat, and some require the same setup for the passenger side, as on the driver's side.
