Common Audio Resource
Hey guys. I have here some common wiring information that'll help out with potential audio upgrades.
Radio 12V+ (Constant): yellow/red
Radio Ground: black/blue
Radio Ignition: (CANBUS) Radio turns on through computer
Power Antenna: (+)black
Left Front Speaker: (+)white ~ (-)white/brown
Left Front Tweeter: (+)green/orange ~ (-)gray/orange
Right Front Speaker: (+)white/violet ~ (-)white/orange
Right Front Tweeter: (+)violet/orange ~ (-)yellow/orange
Left Rear Speaker: (+)white/green ~ (-)brown/yellow
Right Rear Speaker: (+)brown/white ~ (-)brown/blue
RSE Video (rearview camera video): (+)white/green ~ (-)brown/violet
AUX Right(+): blue/green
AUX Left(+): blue
AUX Ground: yellow/green
AUX Shield: black
Satellite Radio 12v: Integrated into the factory radio
RAP 30amp (retained accessory power): brown/blue ~ Located behind the driver kick panel going into the driver door.
Reverse trigger: blue ~ Located in the driver kick panel or at the BCM in a gray 24 pin plug in pin 7.
High Speed CANBUS High: white/blue
High Speed CANBUS low: white
Medium Speed CANBUS High: gray/orange
Medium Speed CANBUS Low: violet/orange
No reason to have anything out of phase now! If anything else is needed, or if anything is incorrect let me know.
XanRules
I've read that the dimmer is also run off the CANBUS, though that may only be on the Focus. For those of us who want to run dimmable gauges, for example, which wire would that be?
S
I'll see what I can get. I'll get to this Thursday cause I'm off tomorrow.
S
It is in fact controlled by the BCM. No way to integrate to factory system. Maybe run a separate potentiometer?
XanRules
Rude!!!!!!
Thanks for the info. I may ask more questions when I start installing in case there's a workaround, but I don't have the wiring diagram in front of me.
S
Rude!!!!!!
Let me know, man. More than happy to help where I can. [cheers]
S
If anybody needs a reference pic, here's RAP.
I'm working on getting a remote start to work with our cars. There's zero firmware from the major companies, and backdoor methods are proving difficult due to the PTS.
