- Member ID
- #3304
- Messages
- 11,945
- Likes
- 8,359
Here we go! Yay!
Here is a list of tools....it will get bigger as I add my tools I used. This little Tool is wonderful to hold nuts in tight spots as you will have to do so in this install or get Ghetto and tape the nut to the 10mm wrench to hold it while you tighten things up.
.The This tool Just allows you adapt easily between sizes if your lazy or don't have the space fro the larger tool to fit in.
Pi
I used A 1/4 inch ratchet due to its size and usability in tight confines.
Then the Rear Diffuser comes with Allen head bolts.....I also used this opportunity to go to the local hardware and buy more stainless steel washers and some Nylok Stainless nuts instead for the Normal ones that came with the kit as I am concerned with Durability and backing out due to vibrations throughout the body of the vehicle.
Now Get two jackstand.....a jack and proceed to put the FiST up. I just used the Center axle beam to use as a jacking point instead of doing each side individually. The placed the jack stands at the rear pinch welds and lowered the car down to be held. No I DO NOT have enough oil at my house....I have a second garage with enough oil to start and Exxon Valdez like EPA disaster.
Locate all the 3 brackets that came In Box for the Diffuser. The First bracket they say to install is the Driverside rear bracket it is held is by the 2 nuts, 2 bolts and 2 washers supplied. If you wanna be able to adjust the diffuser up and down leave them a little loose. This is Mn and we Use salt as you can see the Cancer in my Pics!
The Next bracket is the Passengerside rear this is done exactly the same way as the driverside.
Next bracket is the center bracket near the center beam in front of the Evap. charcoal canister. These nuts and bolts are a real treat to do and if you have larger forearm's your gonna have fun. The nuts and bolts are done blind. This can be done a few different ways I've figured out......You can do this bracket first if you'd like...then do the rears. Its a really tight area to work In but it can be done.
I used my Transmission Jack to hold the Diffuser up while I started to tighten and level everything out. I used a Towel on the jack to prevent an marring to the metal of the Diffuser also.
Then I started to go around and tighten up the bolts. If you want to raise the diffuser up there are provided spacers and longer bolts to lower it if you'd like. I did not lower mine down at all due to an install of lowering springs coming soon so I'm thinking ahead of not having to do the job twice after the springs are in. This gave me a chance to inspect my ceramic coated exhaust also...so far Still good!
Get it all lined up the way you want. Tighten up the Nuts and bolts that hold the shield to the brackets on underside of the Diffuser. Grab a level and make sure its even/ plum unless your into that stance crooked shit. Then lower it back down....Back up and admire your fine looking Aero you have installed. I also have done the side skirts in Vegas motorsports 1 piece and a Rally innovations 3 piece front splitter. Pictures to follow after its all dolled up and washed.
Now kick back and have alittle Drinky poo!
Pi
![Frown [:(] [:(]](/images/smilies/frown.png)
