Engine replacement
Hey guys
Im replacing my 2016 fiesta st blown engine
Ant body knows how many gallons of coolant do i need to buy? Do i buy 50/50 or concentrate?
Do i need need transmission fluid?
Buy two Un-mixed coolant gallons and mix your own. You will NOT NEED transmission fluid. This isn't an Automatic trans ....its completely sealed off from everything else.
A
Do u know if i should change rear main seal or any seals
Dont want any oil leaks since the engine im buying is from ajunk yard
Not a bad idea while the engine is out....I'd be getting OEM seals also....not parts store seals...FYI.
maestromaestro
Or - Liquid chill from Mishimoto. It has magic in it, that's why it's $50 per gallon. I have 2 jars!!!
A
Do you know which seals i should change?
Since the engine is out
This is goin to be my first engine swap
