Ideal engine start procedure?
Victoria, BC, Canada
Hello all,
I'm wondering if it's recommended to use the starter to pump oil for a period before cold starting using the clear flood procedure to lower engine wear during startup
Has this been covered somewhere?
Thanks
felopr
JD
If you haven't started the car in like a month, sure why not
but if you are starting the car like the next day, not necessary.
Is not like all the oil disappear from the valvetrain an such
London, ON, Canada
Just thinking out loud - I could see your idea making some sense for say certain valve train components; You want to move oil at a lower engine speed, potentially reducing wear. However, I tend to think the greater risk is to bearing components. Fluid bearings require a certain level of oil pressure to avoid metal on metal contact. I don't know if the starter speed is sufficient run the oil pump at a speed which will "float" the bearings. I could see your procedure causing more harm than good. Again this is all speculation.
Modern engines are designed to outlast the vehicle. I'd just start the engine normally. If you're worried about cold temperature behaviors, run a synthetic and you're probably ahead of the game.
Hello all,
Thanks
Yes. I've mentioned it at least a few times. (but for top-end versus lower)
https://www.fiestastforum.com/threa...heir-fiesta-st-before-driving.2612/post-52575
https://www.fiestastforum.com/threa...heir-fiesta-st-before-driving.2612/post-52458
https://www.fiestastforum.com/threads/bigger-oil-filter-bigger-than-fl-400s.17314/post-313078
https://www.fiestastforum.com/threads/10w30-oil-in-the-fist.18965/post-333296
From one of the links above.
.......................... give it an extended crank time by flooring the accelerator pedal, before beginning, and during the crank. Release the pedal when ready to start. Avoid stressing the starter with stupidly long crank times. Eight seconds at a time, two cranking periods should be plenty.
unspankable
