Update - 11/14/14
I just mounted these wheels with General Altimax Arctic 195/55/15
Original Post:
I just got a set of steelies from Summit Racing and wanted to show everyone how this brand fits on the FiST. These are Unique 83s, several online tire places carry them, including Discount Tire. These wheels are also branded as Cragar at some places.
I tried to buy a set of winter wheels from Tire Rack and Discount Tire, both were backordered for over a month. After some searching, I found out that Summit Racing carries the Unique 83. Right now, these are $44 each and shipping is free when you spend over $99. So it worked out perfectly for a set of 4. I later found out that Summit sells a even cheaper steel wheel, Allied, for less than $40.
As you can see from the photos, these wheels fit fine. There is about half an inch of clearance between the rim and front caliper. I'll wait til temperature drops below 40F before mounting these wheels. I'll take more pictures when I have all four wheels on the car.
Specs:
15x6
41mm offset
5.125" backspacing
	Original Post:
Specs:
15x6
41mm offset
5.125" backspacing
