A forum member contacted me and asked if he could mail me (free) a mod he designed and printed on a 3D printer. This was a very kind gesture so I happily said "yes". I am looking for insight on whether this is snake oil or legitimate. I know some about our cars but I am not an engineer nor designer so I would like further commentary on the legitimacy of this idea based on understanding of the ECU and tuning compensation and other variables.
It is the infamous "IAT/MAF spacer mod".
From the designer:
"I have been running it for a couple of years now with no problems. I experimented with various heights and this is the max height without affecting the Intake temperature readings. The spacer moves the IAT sensor further outside the intake track and allows for a cleaner and more efficient airflow. Before you ask, I do not know if this adds any horsepower or torque. I can say that I do notice a difference with it installed. This sensor doesn't measure air flow or volume, only the incoming air temps. It is not an MAF, the only thing this fancy sensor does is measure the incoming air temps. You can research this on the forums for a verification. It doesn’t measure the amount of incoming air."
My thoughts:
I have seen these designed and for sale for other platforms. From what I understand I'm having a hard time thinking it will help because the ECU monitors temps and adjusts accordingly. It would seem that if it detects something off because of this mod it will simply compensate elsewhere which could have negative effects because it is basing that compensation on false information. Also it would seem that Ford would space the connector at the optimal place for optimal results. Though it will marginally help airflow/restriction issues, I am concerned that it will also actually restrict the amount of airflow that the MAF sensor can read which in turn causes the engine to believe its running rich, causing the PCM to induce negative fuel trims. From what I understand this will increase MPG but could lead to negative side effects on the valves and cat since the engine isn't running properly. Also I have a custom tune and I am concerned since it is not calibrated for this.
I have only a basic understanding of ECU function and tuning so I apologize if I am incorrect in anything I've said above.
Your thoughts? Please share.
See pics below, it is a very well made piece. It's installed in designer's car, not mine. Mine is the red one, I got bored so I painted it red, but it's still sitting in my garage.
From the designer:
My thoughts:
