P219a and p1450 engine codes
Anyone know what exact part I should get to fix these codes? I read somewhere that’s it’s the EVAP purge valve or something but I wasn’t sure what the part number was. Any suggestions if that’s the part that would cause these codes?
p219a air fuel ratio imbalance bank 1
p1450 unable to bleed up bleed fuel tank vacuum
Have you done any Mods before these codes came up? If so which ones?
hendrixsrv
nothing at all. I had my downpipe installed over 35k miles ago (3 years ago) and my hybrid installed 20k miles ago (March of last year). That was the last mod since. The light started coming on intermittently about a month ago and now it’s popping up almost every time I start my car. I been having issues with the fill up juttering for a while though but it would always disappear after driving a few miles.
Hmmm....ill put money on it's the evaporative purge solenoid having issues. Others have had this issue....maybe they will chime in. What's your mileage? Year?
hendrixsrv
Yeah, probably. Ill blow some air into the purge valve to see if it's open or closed as well. Do you happen to know what the part number is? So far, 62k miles and a 2015
I think you want.....
C1BZ9C915A
Not positive
hendrixsrv
C1BZ9C915A
Not positive
Roger that! Thanks for your help, hopefully someone can chime in as well before I get my hands and wallet dirty!
RubenZZZ
I’m having the same codes pop up after almost every fill up now. 2016 with 68k
hendrixsrv
I'll keep you updated! I'm gonna order the part and see if that fixes the problem.
hendrixsrv
So, I fucked the lines up and now I have to figure out a way to replace those as well. I might go with some high pressure hoses as a replacement. Also, I did a mini test and it seems that theres no leak coming from the EVAP purge valve. So, we shall see. If this doesnt work, I'm gonna replace the Vapor Canister.
I am dealing with the same issue now. Following to see if this fixes it!
