From an Engineering standpoint the tight coils should be at the top.  Because with them down the Unspring Weight is INCREASED, never a good thing for a suspension.  Note, the reason why their is an increase is simple, in a deflection the entire mass of that tight coil stack has to move, put the stack on top and it's not moving that mass nearly as far.  I'll also point out that the purpose of that tight coil stack is to provide an increasing rate of progression for the spring rate during deflection.  Note, almost all springs get "stiffer" as they are compressed but this type of design has the spring getting "stiffer" much faster.  In a very simplified description at some point during deflection that tight section will "bottom out" and when that happens the remaining spring will be much stiffer.  The end result is that this has the potential to produce a harsher feeling suspension over larger bumps.  From a performance standpoint this type of spring design will normally result in less body roll in cornering and a quicker response.
Finally, in regards to the 17" rims I think it's foolish to use this rim size on this car.  I know, it's "Stylish".  It also creates a distinctly harsh ride and and a tire/wheel combination that is much more prone to cracked rims.  NASCAR and
Formula One both mandate a 3 1/2 inch sidewall height for a reason, they don't want to see the results of a wheel failure at speeds approaching 200 mph.  Change to 16 inch rims and both your car and backside will thank you for that, because the ride is much improved and the cornering in a rough corner will be much improved.  I'll also note that the telepathic turn in will NOT be reduced in a change to 16's.
