FS SOLD FS. HS Package: Suspension , Shocks, Wheels, RSB, Tires
Trader history for Andres3165 (0)
Just finished setting up my car , these are the left overs for grabs, all purchased last month , my loss your gain. Prefer local, but will SPLIT GROUND SHIPPING COST with buyer , or will drive some. From 13148
ONLY SERIOUS INQUIRES !!!
email [email protected]
Eibach Rear Sway Bar SOLD
Koni Yellow Sport 1500 miles 3 Autox events $500
(4) Sparco Assetto Gara 16x7 4:108 SOLD
Muffler Delete (6lbs.) SOLD
Thanks for looking
Andres
Thanks for looking
Nice deals here. The yellows are tempting.
CarGuy
How did you do at the Pro Solo? I used to do those in my younger years in an SVO Mustang in G-stock. Fun times and I even won my class in my 84 once and placed a bunch of times.
A
I sucked the first day but starting to learn the car the second day, improved my times but a mistake kept me in 6th (shaking the rust off) I just finished installing the new rear bar, I have the next 2 weekends to T&T it .
Andres
A
Added muffler delete to post
Andres
Do you have the de-gassed yellows, or the MCS factory spring, remote reservoir, coil overs on the car now? [???:)]
Andres
Isn't a muffler required to be HS legal? Or is the resonator considered the "muffler"?
Where was this setup last fall when I was looking. =\
A
No, you can have a sraight pipe behind the Cat, needs to be under 100 db ( i think) maybe 95 db , and exit in the same place as factory.
Which is kind of hard to do with a straight pipe, albeit slightly less impossible with a turbo car.
A
What do you mean hard? Fabrication wise, or noise wise, I tested mine for noise 82 db at the Prosolo last week, which is bellow legal levels, drove 1100 miles no annoying sound.
I'm surprised it was that quiet, as I would have expected you to be a lot closer to that 95 db level, even with our turbo cutting down on the volume output a bunch. [thumb]
(Does SCCA still use the meter 50 feet from the rear bumper, at a 45* diagonal, rev to 4k method they used to check the Pro Rally cars way back when?)
I suspect that a straight-piped NA car, yes, even with the requisite factory catcon in place, would have a much harder time meeting that level.
A
Not sure what SCCA distance guideline is, just to clarify I have a 2.5" FSWERKS (which does not have resonator) with a muffler delete that I made. The one I am selling goes on the factory pipe.
Andres
No, you can have a straight pipe behind the Cat, needs to be under 100 db ( i think) maybe 95 db , and exit in the same place as factory.
Wow this is a revelation. I guess I had heard a muffler was needed, not beause of the rules, but beause of the noise requirements. WIth a turbo, cat, resonator, yeah its not going to be loud... Thanks!
Izzy
Have the Koni's still?
