CHANGE THE CONNECTING ROD
BONJOUR QUELQU'UN CONNAÎT LE COUPLE DE SERRAGE DU ROULEMENT DE VILEBREQUIN.
ET LE jeu axial des vilebrequins ...
Fiestig
Quelqu'un sur le forum peut avoir un manuel d'entretien sous la main. Vous pouvez également contacter directement le service Ford pour obtenir la réponse.
English: Someone on the forum might have a service manual on hand. Alternatively you may be able to contact ford service directly for the answer.
MagnetiseST
Are they asking the procedure to remove the connecting rods and replace it?
Fiestig
Torque specs for crank bearing
Translated...I think: HELLO SOMEBODY KNOWS THE TIGHTENING TORQUE OF THE CRANKSHAFT BEARING.
AND THE axial play of the crankshafts ...
Capri to ST
X
HELLO
THANK YOU
FOR INFORMATION
Since the link above is not working anymore, can aybody post the torque specs for crankshaft and connecting rods for the 1.6 ecoboost engine? Link to the manual would be much appreciated!
MagnetiseST
Wish I'd have saved a copy when I could have. Hes taken his workshop manuals down for now it seems.
Maybe someone here has got one! Workshop told me 60Nm and 40nm, crank and rods. It is obvious that they have no idea and they talked in general.
I would think that before anyone would attempt to rebuild an engine, the FIRST tool they would buy would be a service manual.
Attached is what you need.
Sure! Thank you so much
