Fiesta ST 100k+ Club
Bradenton, FL, USA
Tranny noise?
I know a lot of members have swapped to both a greater amount of fluid as well as better fluids, Amy chance you’ve tried that route?
Yep! Replaced with 2L Motul DCTF hoping it'd make a difference. It's either slave cylinder or input shaft bearing I think.
DoomsdayMelody
San Jose
Here’s to hoping it’s the slave cylinder? Idk I really hope it’s neither.
Vancouver
I'm at 166xxxkm, or 103xxx miles. I've had no issues besides replacing battery, had to replace worn front and rear brakes, and front engine mount. I had a knocking sound coming from the passenger side and I thought it was axle related; I did the powerflex engine mount insert and the knocking sound was eliminated. I have a mountune rmm and I think it reroutes the stress to the other mounts, so upgrading the transmission mount is on the agenda. I have no oil leaks or oil consumption,no coolant loss and no over heating issues. I've been tuned since 107xxx km or 66xxx miles and i have an upgraded intercooler and depo downpipe. I do maintain my car very well with probably excessive oil changes and already replaced plugs 3 times, not that I was having ignition issues, but just for peace of mind. Oil always changed with synthetic and transmission fluid changed 2 times. The 1st time with motul gear 300 and now I am running redline mtlv. The coolant flushed and refilled with motorcraft coolant. I also want to give credit to Randy Robles for his tunes on my car; personally he is the only tuner I trust. Bodywise, I have rust bubbling on the door seams.
DoomsdayMelody
San Jose
Look at this guy and only one set of brakes. Reminds me I should do trans and coolant soon, been almost 7 years afaik.
Vancouver
My driving style is conservative on the brakes lol. I like to engine brake and I don't accelerate when I see a red light ahead. I don't tailgate. I keep a relatively long distance between me and the driver ahead. Ppl always rip by me going wtf and then they slam on the brakes after turning into my lane, realizing I was actually maintaining same speed as the driver ahead, not going slow. . I do however, do some left foot braking when doing some spirited driving on mountain twisties or when I feel like going really fast on a turn.
California
Bought my 2019 Fist in California with 101k. Everything has felt solid and the car was maintained clean. I'm doing an oil change soon, are you guys still running stock weight oil or should I do something a bit different at 104k now?? Thanks!
Mesa, Arizona, USA
bought my fiesta in oct 2023 with 139k. it's now at 160k and running strong. im on dizzy stage 2 e30 tune right now & it pulls real hard. enough power to have fun, but not get me in trouble.
throwing fresher stock suspension in on saturday (30k miles on front & rear struts & springs, i don't have bilstein & lowering spring money). had to replace a bent wheel last week. i don't seem to have any major issues beyond trans whine and clutch chatter (which the clutch needs to be replaced soon).
i did have the o2s replaced due to a random code that would keep popping up & had to replace rad fan assembly due to the module failing a few months prior.
Maryland
Just turned 109K miles. No major issues beside radiator fan plug melting and the fan stopped working on the hottest day of the summer. Replaced the fan and then had to replace the battery because that was the real issue. Low voltage. It was stage 2 E30 dizzy tuned from 60K till about 100K. Now S280 tuned on fuel and E50. Been running the S280 and E30 for about 7k miles and 2k miles E50. No hiccups as of yet. The stock clutch is due for replacement and would slip on occasion with a NLTS 3-4. I have a Whoosh stage 3 ready to go in though the stocker is holding for now with colder temps, more power and less traction. Blend door actuator once a year it seems. She's been great (Knock on wood).
San Diego
I'm by no means any type of expert, but based on research I did when I bought my Fiesta ST earlier this year, I started using Pennzoil Ultra Platinum full synthetic 5W-30. I've gone through a couple oil changes with it, and everything seems to be running great. I plan to do a Blackstone Labs oil analysis next oil change.
California
Awesome, thanks for your feedback, this is my first "new" car since owning a 2001 Honda Accord since highschool. In my Accord that had over 200k, I used higher weight by 10 as well because I was told it would last longer and not burn up. Not exactly sure how true this is because I'm also not a car expert. I've also heard that using full synthetic is the way to go, not sure really. That's good! I'd be curious to see your results, let me know if possible! Thanks.
Capri to ST
CHAPEL HILL, NC, USA
You definitely want to use full synthetic, it's great stuff.
I don't use a higher viscosity, I feel more comfortable with the recommended 5w/20. I think there's a good reason it's recommended,like the tight tolerances in modern engines.
California
#33
Ok I can see that, how many miles you at? Thanks for your feedback.
Sheboygan
#35
Agreed. I’ve had my car since it was new in 2016 and just broke 200,000 miles. Good oil has kept it happy.
Sheboygan
#37
Impressive. What repairs have you done?
-rear calipers locked up, had to replace them.
-blend door actuator went insane, had to replace.
-the push button on the passenger side exterior door handle quit, had it fixed under warranty.
-tie rod end sheered in half, replaced both. (The car did a lot of track time, so I’ll forgive this)
-Otherwise it’s been routine fluids, tires, brake pads, and light bulbs.
Edit: I forgot to mention the relay for the radiator fan crapped out a few years ago. As cheap as it is, I should probably fix that.
Sheboygan
#38
I’m actually shocked at the amazing reliability of the car. I bought it expecting fun, but didn’t expect this. I went upgrade happy when it hit 5000 miles, had it tuned by Tunes+, thrashed it for over 2000 miles at speed at Road America, and drive it year round in Wisconsin. Maybe I got lucky, but other than a little rust starting to form, it’s just as good as day one.
Capri to ST
#39
That's an impressive lack of major repairs for a highly modified car with over 200,000 miles on it that has had lots of track use.
rallytaff
Los Angeles
#40
Still have my 2014 with nearly 111,000 miles with blend door actuator replaced once under warranty. All belts, water pump and thermostat assembly, drive belt tensioner done at 107,000 to save any problems later. Clutch and flywheel replaced when I had the WaveTrak installed. Mountune radiator fitted but wasn't needed. Just playing safe. Runs like it should, fast and fun!
