Complete Knuckle & Wheel Hub Assembly?
My Driver side rear has killed it’s second bearing in under 4 months. I think it’s time to replace the whole assembly, as something has to be causing the premature failure.
Part Number - C1BZ5A969A says it’s a rear wheel knuckle and hub assembly. I ordered it, and Ford only shipped the damn knuckle.
Here’s a link:
https://parts.ford.com/shop/en/us/steering/steering-parts-other/knuckle-and-hub-assy-6404095-1
So if this is incorrect, is there a part number I don’t see that will be the whole rear assembly? I’ve checked other sites as well, and it appears as if you can’t get a full knuckle/hub for the ST anywhere. What’s the deal? If you were to order all the 9 parts separately, it would be well over $300!
Sometimes it is best to TALK to a Ford parts dealer to make sure you get the correct part.
You could try this number DCPZ1104A
Peterson
That part number is for a non ST fiesta. Not for our cars.
I did. And she told me it was the whole thing. Then when the wrong part came, Ford parts told me to just take it back to the dealership I got it from (I ordered online). So that wasn’t very helpful either.
kevinatfms
It is a torsion beam with a bolt in hub. Are you thinking of the caliper bracket? Or are you trying to buy the torsion beam or the hub/bearing assembly? If the bearing is dying after only a few months you either have issues with bad quality parts(use Ford OE) or a bent torsion beam outer stub which is quite rare if you have never hit anything.
Erick_V
Are you trying to buy the torsion beam or the hub/bearing assembly? If the bearing is dying after only a few months you either have issues with bad quality parts(use Ford OE) or a bent torsion beam outer stub which is quite rare if you have never hit anything.
Sound like he’s trying to buy the entire hub assembly. Don’t forget to pick up the 8 bolts too, they’re stretch bolts
kevinatfms
I see what he is saying though.
If you search for the rear subframe and associated suspension items it shows a rear knuckle which is not correct for the application. It should show a bolt in hub/bearing with a caliper mount next to it. But it shows a pass through knuckle design which isnt correct.
JDG
Here’s a link:
+1, DCPZ-1104-A is what you want... See below:
https://www.ebay.com/itm/Genuine-Ford-Hub-Bearing-Assembly-DCPZ-1104-A/193705097794?epid=1311117834&hash=item2d19b93a42:g:dEEAAOSwgxpfgnY3&fits=Year:2016|Model:Fiesta|Submodel:ST|Engine+-+Liter_Display:1.6L|Make:Ford|Trim:ST+Hatchback+4-Door|Engine:1.6L+1596CC+97Cu.+In.+l4+GAS+DOHC+Turbocharged
jeffreylyon
You sure? The pictures included in that listing show a drum brake application and the hub looks like it's got holes to access the adjusters. The ST hubs have no additional holes, which is important for us 4x100 folks.
Peterson
You guys are all linking to the NON ST version of what I’m after. The ST has a different rear knuckle/bearing/hub than the base Fiesta.
Erick_V
But when you scroll down to fitment in includes the ST
JDG
I think they use the same hub. You are going to have to ask your local dealer but I would say you should be good.
Peterson
Confirmed at dealership. Ford does not sell a full assembly. You have to buy all $300+ worth of parts and build it yourself.
Junk yard it is...
