P0299 code low boost code
Bellflower, CA, USA
Ok .. used a OBD ii 2 reader on car because it seems to run in a “ granny “ mode since ECU replacement.... i hear turbo spool but no PSSH sound .
NO DASH FAULT LIGHT
NO WRENCH LIGHT
Idles under 1000 rpm - stable
Rev up and release - idle normalizes
Driving car - seems fairly normal but no real pull in 3rd. Seems like im in some kind of valet mode. I heard ECU needs to re-learn driving habits to setup - . But will double check intercooler hoses and such ( maybe boost leak ? ) or ?
Not sure where to start . There is NO TUNE installed. Should I disconnect neg. and let ecu clear ? Or where else to look.
Help
NO DASH FAULT LIGHT
NO WRENCH LIGHT
Help
Recent repairs or Mods? List of Mods also and mileage?
Darkflamedesign
Bellflower, CA, USA
26000 miles on Fist 2014 ( a baby still )
Whoosh intercooler
Ingen cold air intake
Boomba symposer delete
MRBP exhaust
ECU was replaced by ford ( free ) driven about 150 miles SINCE ECU was changed. Feels underpowered at 2 and 3rd gear .... No engine lights or irregular driving just noticeable lag ( power ). Plus that Pssh is no longer noticeable. Wondering if DV is an issue was going to upgrade GFB DV+ but want to figure this out first.
Car start fine , drives “ normal “ city but mashing gas it seems to not pull as it did.
I'll have my money on a boost hose leak or Boost hose blown off on the Hotside * That is where i would start! Good and update when problem has been resolved!
Darkflamedesign
Bellflower, CA, USA
Well , seems like I corrected issue after DOUBLE up on clamps ( both sides ) .
Boost is back , but will change charge pipes ( ordered ) ... noticed the OEM are very soft so they will be swapped out. Used T bar clamps .
@TyphoonFiST Thanks a bunch.
