Help with clicking coming from glove box
Phoenix, AZ, USA
So I just noticed today that there is a quiet constant clicking (2 clicks about every 10 seconds) coming from the glove box. I touched and listened to every replay and fuse in the box and it’s not any of those. Then I inspected the body control module and it’s coming from this. I unplugged and reseated all connections. When I unplugged the green plug the clicking stopped and the error is for tpms sensor. So I’m wondering what I need to fix at this point. Seems like there is relays inside the bcm. Can I open it up to change out or do I need a whole new bcm? I’m not getting any tpms or other errors when everything is plugged in just an annoying non stop clicking. I’m guessing it’s going to keep going because the car is constantly checking if the tires have enough air in them. Any insight would be very helpful. Thank you.
XR650R
Eerie
You're sure it's not the right side blend door actuator?
STbro
Phoenix, AZ, USA
No it’s definitely not, that’s the first thing I thought of because I just replaced mine with a new one and thought I got a dud. But I tested this with the new actuator unplugged and I traced the sound to the bcm and am getting the relay ticking sound when the ignition is on and the green harness is plugged into the bcm. I had my hand on it and felt the relay ticking coming from this unit. I hope I don’t have to get a new bcm and then have to pay to get that programmed. If anyone had a wiring diagram and what those wires do going into the green plug that would be very helpful. I could only see the tpms error thrown when I unplugged it myself.
DoomsdayMelody
San Jose
When are you hearing the clicking? I noticed a similar noise any time I got up above 50 mph, somewhat intermittently, turns out the weather stripping on the passenger side of my windshield broke a few locating tabs and it not kind of jiggles when the wind catches it right.
STbro
Phoenix, AZ, USA
The clicking happens when there’s power to the system. As soon as I push the start button into accessory mode it does 2 consecutive clicks every 10 seconds. It does it when the car is running as well and it’s non stop until I turn the car off.
LilPartyBox
NYC
Turning on the heated seats creates a click from the glove. Maybe it's related??
DoomsdayMelody
San Jose
So it’s electrical for sure, could always start pulling fuses to see if you can get it to stop? If it works that means you’ve isolated the system, and can troubleshoot from there.
Never mind looks like you already knew that!
STbro
Phoenix, AZ, USA
Yes I tried that first actually and pulled every fuse and inspected, then I put my head closer in there and heard it from the bcm and traced it to the green harness that I pulled. I’m going to get forscan so I can replace the bcm and reprogram it. Definitely curious on opening my bcm unit up to see if there’s any issues I can detect.
STbro
Phoenix, AZ, USA
Update for the issue:
It’s still ticking and it’s the equivalent to Chinese water torture. It’s quiet but non stop consistent ticking is driving me crazy. I hijacked my girlfriends old windows 7 laptop and downloaded forscan. I got the forscan certified OBDLinkEX adapter from Amazon and after hours of reinstalling windows 7, installing updates and updated drivers to the adapter I finally got it working on my car. No codes found. I saved and reloaded the bcm settings thinking that could maybe fix the ticking but it was a no go. Next step I’m going to purchase a new bcm but when checking the part numbers on mine I could only find used ones on eBay. The other ones have an updated part number which I’m sure would work for my 2014 but not sure about that. On the other hand the used ones on eBay could have issues with them being in crashes and with miles on them. Any advice?
My bcm part number is av1t-15k600-lj
The new one I found is DN1Z-15K600-S
https://www.tascaparts.com/oem-part...vPWZpZXN0YSZ5PTIwMTQmdD1zdCZlPTEtNmwtbDQtZ2Fz
Atlanta, GA, USA
I may be a few years too late. However, I have had this issue ever since I purchased my FiST, and I just thought it was normal with these cars since I replaced both blend doors when my driver side went bad. But the clicking continued, and I once again thought is was normal. Well, two weeks ago my fiancée purchased a FiST of her own and I noticed it did not have the intermittent click from the passenger side. This led me to start investigating this week, and I stumbled upon this forum which pointed me in the right direction. The clicking does in fact come from the BCM relay. Upon further inspection I realized the key difference between my car and hers is that I have a rear wiper delete and that is the only modification related to the BCM. I almost purchased a new BCM since they are so cheap, but I held off to make sure I was not overlooking something stupid(I was). Well, the root of the problem was the rear wiper stalk was clicked on just barely to where I did not notice it at all. This in turn leads the the signal being sent to BCM the BCM clicks the relay on and once it realizes the rear wiper is not plugged into a motor is clicks itself off and it will continue to do so the entire time the vehicle has accessory power. So, before you go and try to replace your BCM like I almost did and you have a rear wiper delete make sure the stalk is not just barely clicked on one notch. I hope this helps anyone that has encountered this very annoying issue!
Nashville, TN
Buddy you just saved me a big headache. I just picked up a 2017 to replace my 2014 and this described my exact situation. If you're still on here, I owe you a beer!
Houston, TX
Ah shit thanks so much man! Had the exact same issue you saved me so much headache
