Mountune Quick Shift Back to Stock
Brianmc27
Does anyone have a write up on how to return the Mountune unit back to stock? How does one go about getting the ball back on to the shift arm?
Thanks!
Capri to ST
Thanks!
Thanks!
I can't help you with how to do it, but I'm just curious why you're doing it. Are you unhappy with it in some way?
XR650R
Do you have the tool that comes with the quick shift? Use that to pull the pin, then use some loctite to put it back to original.
Brianmc27
Brianmc27
I think it's the greatest thing since sliced bread! I have it with the shifter base and trans mount solid bushings and I love it.
Just starting to part out.
DangerMouse
It’s not the easiest to do. I had to do it when i installed the coolerworx. I removed the whole shift assembly from the transmission. Carefully put it in a vice and used the mountune pin removal tool and a dead blow hammer to get the stock pin back in the shifter assembly. If you are parting out the car, I would probably just leave it on and let the next owner have it. Not really worth the trouble. Here are a couple pics before and after. Doesn’t really help but it is possible to do. Just depends on how much work you feel like doing. Feel free to pm me if you have any questions.
^^^Yeah, IF this car ever goes, for ANY reason at all, even a repo, they can have my Mountune short shift plate, AND the boomba under hood bracket bushings as well. [wink] [:)]
