Prior car, knocking noise was the rack and pinion. 100k+ over rough streets had worn the pinion gear. Wasn't a safety issue, didn't affect handling and couldn't feel it in the steering/wheel. Dealer mechanic pinpointed the noise with a stethoscope. I later replaced the rack & pinion myself. The part was $300 at the dealer. Paid a shop to do the alignment though, they didn't really have anything to do as I compared the OEM and replacement to match up the tie-rods.
To state it again, you can't tell whether your rack mount nuts are loose without putting a torque wrench on them. If regular movement is allowed, it may damage the rubber bushings.
