2014 Fiesta ST Engine Replacement
So Cal
Hello. My 2014 fiestas engine might be toast at 110k miles. Where do I buy a used or new engine replacement? I’d have the swap done in my garage.
Start checking local Junk yards or yard finder on the good old interweb! Or you could get fancy if you have the coin and get one from a vendor like Mountune.
check craigslist, check car-parts.com that could clue you in to the local junkyards here. I would say you should be able to find a Escape engine which is the same as ours pretty easily somewhere in SoCal if not an engine directly out of a FiST. There are a lot of junkyards in SoCal.
Dpaul918
U.S. Marine Veteran
Mendota, CA, USA
It is a St Ecoboost 1.6l or it's non turbo 1.0 l engine... I send you a link to where to go and find
one
T
So Cal
It’s for an ST
Yeah that’ll be great.
T
So Cal
Found an engine from a local junkyard. Pulled out the engine today. Going to order clutch fluids etc. anything else I should order ?
Engine Out: 3CDFD4F0-0E8C-4F56-B279-616ECC2A35F5.jpeg
Old engine :
Replacement Engine :
T
So Cal
Got the engine in and trans. Wired everything up. However the clutch pedal doesn’t have any pressure it just stays fully depressed in when I push it. I put a new slave cylinder. Any ideas ? Do I have to bleed the clutch ? Thanks
There may need to be certain programs brought back online with a scantool or forscan*
kivnul
U.S. Army Veteran
Deer Park, WA
Clutch bleeding is a pain and hit/miss. Read up on it. I’m remote so I don’t have links.
T
So Cal
So I have the engine and trans in. Clutch is bled. I hit start and it stalls out. I believe I’m not getting an fuel. I checked fuel lines all good. Any ideas on what to do ? Engines compression is good. The engine has 48k miles and was from an escape that suffered a front collision.
The CKP sensor/ crankshaft position sensor may need to be re-programmed.
Nikke21
Soledad ca
Where would one get these sensor reprogrammed?
I have the same story but after the swap the check engine light shows p0365 and p0369
Andree
San Diego
Did some of you manage to make it run? I might have to replace my motor soon too 0_0
