Tech tip for wiring.
Cranbrook, BC, Canada
Not sure if anyone posted this before, but just a little tip. I wanted to hardwire my Uniden R7 Radar Detector and I wanted to use an Add-A-Fuse in the fuse box. I don't like to tap into circuits and have random fuses all over the place...I like my fuses in the fuse box, what can I say. Well trying to fish a wire from one side of the firewall to the other proved daunting. Then I remembered there was the flex tube that the Symposer used that goes into the cabin. I had already deleted the Symposer so I pulled the hose apart inside the cabin at the joint and I tried to fish a coat hanger thru, but the bend was too sharp. So I tied a knot in a piece of string and blew it thru the hose with 80 psi of compressed air. It came out just at the back of and below the battery box. A perfect conduit for wires!!!
Selden
Good tip! Wish I knew this when I ran the wire for my e30 gauge!
Sent from my SM-N986U1 using Tapatalk
flbchbm
Sterling, VA, USA
Nice! What would your estimate be on how much you could get through there? What gauge wire? (yes, flexibility varies) or a vacuum hose, etc.
ywgbandit
That tube has to be about a 1 inch ID tube. I would think you could get a pretty big wire and a vacuum hose thru there. It would have to be flexible because there is a pretty sharp bend right where it goes thru the firewall. I never tried anything bigger than the wire I needed, so I'm not 100% sure?
flbchbm
Sterling, VA, USA
If I could get my hands on some kind of slippery, teflon-like, super-thin collapsable tubing (think expandable hoses), it could be blown through and then wires could slide through easier. Does such a thing exist?
EDIT:
Amazon.com: MGI SpeedWare Woven Mesh Split-Sleeve Wire Loom for High-Temperature Automotive Harness and Home Cable Management - 25 feet (3/4"): Home Audio & Theater
Amazon.com: 20ft 1 inch Cord Protector, Braided Cable Sleeve, Split Wire Loom Tubing, Cord Wrap Organizer for Computer: Home Improvement
I could use the remainder for the trailer wiring in the car and on the trailer.
ywgbandit
Once I blew the waxed string I was using thru the plastic hose it was very easy to pull the wire thru with the string. It was harder to pull the hose out of the connection up inside the dash, but a good pull on it separated the hose
PhoenixM3
Colorado Springs
I had a similar idea for routing my ALP sensor wires. Didn’t know about the 90 bend though. Thanks!
flbchbm
Sterling, VA, USA
Network cable PULL STRING. I have plenty of that.
