Reverse is dead
its_stock
U.S. Air Force Veteran
Tokyo, Japan
So my car decided it didn't want to go into reverse anymore today. I've installed an LSD lightweight flywheel and spec clutch about 10,000 mi ago 100% problem free untill today. But today when I went to back into my driveway it felt like the transmission was kicking the gear selector out of gear when I started to release the clutch. Has anybody else had a similar issue? Everything else is working perfectly all the foward gears are great reverses my only issue.
Cable Adjustment?
its_stock
its_stock
Tokyo, Japan
I plan on trying the cable adjustment tomorrow it just seems very sudden as my car went into reverse this morning with no issue. Heck it went into reverse when I left work 45 minutes ago but when I got home nothing just dead.
MagnetiseST
Dania Beach
Put it in reverse with the engine off, then start and let the clutch out. See what happens.
its_stock
its_stock
Tokyo, Japan
Tried this and the car still kicks out of reverse as soon as the clutch starts too engage.
MagnetiseST
Dania Beach
Sounds like your shift fork for reverse is bent / bad, or your synchro set is bad. There could be something up with the reverse bearing too. Remember that the reverse gearset is separate from the other shafts. Do the rest of the gears work without issue?
MagnetiseST
Dania Beach
Adjust the cables, see what happens. If its still bad / not working you can pull the shift selector out from the top (2 10mm bolts, and unplug the reverse sensor) and take a look inside. Most likely won't be able to see anything without total disassembly though.
its_stock
its_stock
Tokyo, Japan
No love adjusting the cables, or putting the car in gear while turned off. Looks like the transmission has to come back out.
Sam4
West Chester, PA, USA
I'm losing reverse too. It'll jam to a stop as if i went into a hole - only once in a while though. Does it have anything to do with the lock out? Just wishful thinking with 5th already popping out.....
MagnetiseST
Dania Beach
Something is up with your synchronizers or your ball detents (little sprung balls that hold the synchronizer assembly in place)
its_stock
its_stock
Tokyo, Japan
So I've been playing around and everything feels perfect in my transmission. I did the cable Adjustment as recommended by the group. No change but it was super easy so why not. My gear shifter feels like reverse is fully engaged, but as soon as I release the clutch it kicks out of gear. I can hold the shifter in position and lightly feather the clutch to reverse the car. That's gonna have to be good enough for the next few months till it cools off here in AZ. There is no way I'm pulling the trans in 110f+ weather.
Sam4
Thanks - you've been responding to me/my tranny for a while now. I stand firm in believing that ford screwed the pooch on the tranny and I guess my only hope is Pumaspeed. Of course $3 grand and my only hope will be a quiet divorce - nothing with guns or knives.....
MagnetiseST
Dania Beach
Why Pumaspeed? Clarke transmissions in Orlando, FL does rebuilds / mods to the IB6 transmission. Of course you can also find a used unit for sub 1k prices most of the time.
