Persistent problem with car breaking up under load
Burke
So after installing a Sub and amp the other day after letting my car sit for about two weeks I had some weird issues/problems when I started her back up.
Initially had to jump her and on first start up, I went to go into first let out the clutch and gave her gas but got no response from my gas pedal. Checked to make sure my power line from my sub wasn’t blocking anything, As I went through the fire wall but saw nothing in the way. Turned my car off, went to turn it back on and the battery died. Weirdly wouldn’t jump at first but after fidgeting with the jumper cables a couple times it finally did. Once I got it jumped again, my gas pedal responded and I was able to start moving. Shortly after driving a short distance out of my neighborhood in first at low rpms, I got out on the main road and as soon as I got around 2500 rpm’s in first the power started breaking up and dropped down to a low idle then the motor shut off as well as white smoke out the back. Struggled to start back up, like it wouldn’t turn over just kept cranking then when it did it idled super low.
The below pictures are the codes it threw:
After reading a bit over night, I saw it could be as simple as reflashing the ECU. Tried that today, car started up fine but like the day before as soon as I got to 2,500 rpm’s it started breaking up. Didn’t stall out or die but happened every time I got to the same general RPM area.
I also read it could be the gas pedal position sensor. Battery holds a charge and charges fine, reading 14.5v while on.
Any insight is greatly appreciated, hoping it’s a simple fix before I drop 200$ on a new sensor.
Mcsmiff
Burke
Ive had the problem prior with it breaking up under load but it went away after doing it maybe once or twice. Originally what I thought had caused it was a bad coil boot, got a new ignition coil and it went away but now it’s back.
I'm guessing the sub install has something to do with it.
What kind of coils did you install? Parts store brand? fomoco brand? I cant say this enough... ALL Coils should just be replaced every 50-75k as overall maintenance as the windings break down over time and aren't able to transmit power as precisely as when new .Just like o2 sensors get dirty and become less responsive due to dirty exhaust over the thousands of miles driven.
Pleasant Garden
I would definitely check the wires around the accelerator pedal. Follow the wires if you can. This has nothing to do with Ignition you have a code for the accelerator pedal. Obviously something is wrong with the accelerator pedal. With a scan tool that can read accelerator pedal position you could see if pedal is communicating throughout its entire range.
"So after installing a Sub and amp the other day after letting my car sit for about two weeks I had some weird issues/problems when I started her back up."
This tells me obviously something was damaged during your install if the problem did not exist until you did this work that is what did it.
Sent from my SM-A526U using Tapatalk
Where did you ground and power the Amp from also?
Mcsmiff
Burke
Power is from a 4ga line ran directly to the battery and ground is from an open hole from where I removed the rear seats.
Mcsmiff
Burke
I replaced all 4 with lower mileage oem coils that had maybe 40,000 miles on them. I’ve been suspecting it’s the coils going as well though to be honest by how it breaks up under power right around the same RPM.
You routed the power wire through the fire wall correct? If so....did you have to unplug anything to move things out of the way to get it through?
What is your current mileage?
Mcsmiff
Burke
I’m 99% sure I didn’t, I had already made a small hole through it next to the symposer line for my light bar switch setup and so I just pushed the rigid 4ga wire parallel through it til I made it into the bay and pulled what I needed from the engine bay outwards. Checked all my cables and plugs today after work to verify. Power line was kinda close to the clutch relay/switch so I moved that but no cables looked nicked or pulled out.
Do you still have your symposer hooked up or did you disconnect it? You could've maybe ran the wire through that I do believe.
Leavenworth, KS, USA
Have you had the sub/amp hooked up the whole time while trying to troubleshoot this?
I’d start with removing the in line fuse that powers the amp and see if the problem still persists. Also what did you tap into for a signal to the amp?
Mcsmiff
Burke
67,000mi
Symposer is removed, I tried running it through the symposer line but couldn’t get it to go through so I gave up on that option.
Mcsmiff
Burke
yes I’ve kept my amp and sub hooked up the entire time. I’ll try that today. I’ve spliced into the right rear speakers through the passenger’s side, opposite side I ran my power line.
