Speedometer, tachometre and fuel gauge quit working...ideas?
Just as I said. The needles of those three items on the dash are fixed to the bottom. It just happened out of the blue. I started the engine after getting gas and they didn't move. I drove two hours and turned the car off for six hours, thinking they might "wake up" or reset somehow, but nothing. I stopped at a dealership on the way home and one of the sales guys fiddled around, checking if a fuse had blown, but not a fuse.
Any ideas?
Bill Schmid
You could try a instrument panel test.
Hold the trip button down, start the vehicle. Keep holding and it will enter a test mode. Should do a gauge sweep on one of its tests. Will also do a digital readout out of rpm, fuel level and mph.
How is the current health of the battery and its age?
B
Yes it enters test mode. Didn't know about that. Needles did not move...no gauge sweep ever. I advanced through the entire list of items and a sweep never occurred. There were a ton of codes shown, etc. Are any of them important?
The dealer guy last night thought it was a computer thing, not the main computer, that runs those needles. Yes?
B
The battery is 2-1/5 years old and seems to be in perfect shape. The car is a 2019.
Keyword here is "seems" it should be tested as a battery on the fritz can cause electrical issues as these cars are CanBus systems* I'd check its state of charge and maybe even charge it just to eliminate that from the picture.
B
Could I battery do everything perfectly and still be "on the fritz"as you said? I have an oil change coming shortly and I'll have it checked.
Make sure it's load tested* and filled with electrolyte.
PhoenixM3
Definitely the turbo. 😎. Sorry, can’t help.
B
Any ideas?
Bill Schmid
Here's a weird update. The needles are now working again.
When the dealer guy checked for a fuse problem, he only checked in the fuse box under the hood. Yesterday I learned there is also a fuse box behind the glove box, and that the fuse in F3 controls the dashboard.
So I removed it to check if it was burned out. It was not.
I also started the car and checked to see what all was dead when that fuse was removed. Interestingly, it was everyting on the dash, lights on knobs, etc. So I put it back in and started the car again to make sure lights, etc. came back on. They did, AND THE NEEDLES MOVED AS WELL.
It's fixed? I guess. I'm driving the car in an hour and hope they still work.
Very strange.
Very strange.
Electrical Gremlins!
Sounds like a bad common ground/power feed and/or a loose connection.
haste
I've had ECUs go on the fritz and removing all power from them, essentially "resetting" them, has fixed the issue. Hopefully it is not a recurring problem for you.
niesga
My speedo and tach work, but the other gauges do not (temp, gasoline, and so forth. ) what are the possibilities it's an electrical problem or the cluster itself? Also, is it a tough activity to update the cluster? I'm pretty mechanical. Appreciate any mind.
Tutuapp 9Apps
