Fuel Pump Wiring
Northern Virginia
Anyone have a wiring diagram for all leads out of the fuel pump under the back seat?
I want to add an inertia kill switch. Since the interior is stripped down anyway (track car), it would be easy for me to grab one of the lines at the pump … assuming there is a lower amp feed there that would kill fuel supply if cut?
U.S. Navy Veteran
SFV, So.Cal.
You might check your fuse panel or invest in a cheap multi-meter.
cidsamuth
Northern Virginia
I have the multimeter …. just hoping you had a quick answer so I wouldn’t have to spend time poking wires. Im looking to confirm if I needed to use a relay or whether the inertia switch could handle the current on its own.
Regardless, thanks for the wiring diagram; it helped a lot.
U.S. Navy Veteran
SFV, So.Cal.
Sorry, I don't know without testing myself.
U.S. Navy Veteran
SFV, So.Cal.
After looking it up:
In the under-hood battery fuse box, the fuel pump is controlled by the fuel pump relay.
The fuel pump fuse is 30A.
