Oil on plug
Hey guys please help
Have had a bit of a misfire in higher gears around 3k revs using anymore than a little bit of throttle
Took plugs out earlier and cylinder one has oil on the spark plug threads and a bit on the coil and in the spark plug well
Not a lot but assuming this is the reason this is mis firing
Any ideas why this would happen
Thank you
Thank you
Valve cover gasket leak?
L
Ju
Just remembered spilt some oil when putting some in
Would this get past the coil pack?
Ju
Anything is possible *
