Spark plug not coming out
Nscragg
Hey y'all,
I've been trying to change the spark plugs on my FiST and all of them have been able to be pulled out except for the one in cylinder 2. It's completely loose and can be moved around, however, it will not pull out of the slot, it can't be tightened or loosened either. Any help would be very much appreciated and I've attached a video to show what's going on.
Cheers
Jabbit
Upload the video to YouTube, I'm not about to download someone else's file. Can you get a photo through the opening?
SteveS
The video shows him using the spark plug wrench to wobble the spark plug around.
Have you tried reaching in with something that can grab the plug and pull it out? really long nose pliers?
They are metal....so magnet them out* or buy a snap-on socket and never worry ever again.
Sam4
Maybe used a standard-walled socket and grabbed just enough to get in trouble. Thin-walled socket needed...
Have you tried using a short length of silicon rubber hose? Cannot remember what ID I use but it fits tightly on the porcelain insulator. That is what I use to remove the plugs on my '15 Focus ST after loosening them with a socket wrench of course. (480,000 miles-has had MANY changes) Have not done one on my '19 FiST (25,000 miles) as of yet.
Jabbit
You have a Focus ST with 480k miles? Going to need more details on that.
Fiestig
I 2nd the magnetic socket. Love mine. 3/8" rubber line would work, or you can fish it out with a looped wire. My farm kid up bringing could probably come up with about 40 other ways to get the job done, but that eventually usually comes down to spray the f'r with ether and hope for the best.<-- Don't do this by the way. My cold weather old head peeps will know what I am talking about ...lol.
Wow, that's the most miles I've ever seen on an ST. Are you still on the stock engine and transmission?
All stock, no major driveline work done, original clutch only a water pump, some stab links, 2 evap valves (surprise!) and of course brakes and tires. Struts and shocks being replaced soon. Damn reliable machine.
FiestaSTdude
Original clutch!?!?
Wow, that's very impressive! I'm glad it's lasted so long. Hopefully the fiestas will prove to be equally reliable long term.
I 2nd the magnetic socket. Love mine. 3/8" rubber line would work, or you can fish it out with a looped wire. My farm kid up bringing could probably come up with about 40 other ways to get the job done, but that eventually usually comes down to spray the f'r with ether and hope for the best.<-- Don't so this by the way. My cold weather old head peeps will know what I am talking about ...lol.
Seconding the magnetic socket. Purchased mine after seeing others using them on here and it made the plugs a breeze. Thin walled enough for our vehicles and the 6 inch length was just enough.
https://www.amazon.com/gp/product/B071ZT9VZK
