Black Ferret ST2 - FiST from Poland
none
Cruise control is coming ;)
Forscan can enable it. You should have cables already in the steering wheel to support it. I did it with my 1.0 EcoBoost and only hassle was getting the airbag out. The rest was a breeze. I took the plastic cover off the steering column to access the airbag release springs. Turned the wheel 90 degrees each way for each side.
BladeRunner
Warszawa
Thread Starter #24
I already have it enabled. Although I did not have the wiring.
Secondly - that "fascia" was bough off the Ford Ka+ and it does not fit. I has different fitting holes and different wiring, which frankly speaking it is quite strange for me. Same decal - different fittings? Not make sense...
So... Back "to the old drawing board" and once again looking for CC ;)
none
That fascia look perfectly similar, but the tiny differences are hard to spot. I bought an entire wheel from a wrecked/scrapped older model Fiesta on ebay. Buttons should be interchangeable. But pre 2012 i believe the backlight is red. Only difference. Also the radio control is different from bluetooth enabled and non-bluetooth models.
You can search for a Fiesta version: https://www.ebay.com/sch/i.html?_fr...&_nkw=ford+fiesta+mk7+steering+wheel&_sacat=0
EDIT: Those prizes are crazy for the parts. Making this seem like a good deal: https://www.ebay.com/itm/4041734250...2UL9JUaVrESa6VhrmuXz0UMnMw==|tkp:BFBMqM_Hu_9h
BladeRunner
Warszawa
Thread Starter #31
Suspension update :)
Eibachs are in :) rear springs were broken, so just in time:
Front strut brace:
Sandwich plate for oil temp gauge:
BladeRunner
Warszawa
Thread Starter #34
Rims for summer:
Dyno results without mapping (yet). EUDM stock data: 180hp / 240Nm
none
#35
Isn't that rim dented on the top in the picture? Sure looks like it.
