Hybrid turbo with minimal supporting mods
pelotonracer2
NRH
I'm picking up a used Fiesta ST and want to go hybrid turbo (Whoosh), intercooler upgrade (unless this car already has one, I see it already has a bigger aftermarket radiator), Cobb AP, colder plugs, a tune, GFB DV+ and an AFE or Green filter inbox. I don't want to get a downpipe, exhaust or intake because I want it to sound stock (and I had issues with Cobb catted downpipe throwing codes so I'd have to upload a stage 3 OTS Cobb map and run it with my Pumaspeed X47R in order to get it inspected).
Has anyone done this?
I spent a TON of money on my last FiST (you can look at my build under that section) and I'm not doing all that again. I'd like to pop the hood and have it look and sound stock but also be around 275-290hp.
Dialcaliper
San Francisco Bay Area
Honestly I think you’ve checked all the essential boxes - the only thing I’d add is to get better clamps on the intercooler hoses, or double up on them.
You might be leaving a few horsepower on the table, but not as much as you’d think (the stock intake, downpipe and exhaust are actually not that bad. Most of the other upgrades are mostly for noise, looks or reliability. An OEM ST200 lower Airbox could be a useful upgrade that is pretty low profile if you want to go that route.
[thumb] I like this concept, as I am not one much for under hood bling myself.
I'm still with the factory snail, but except for no engine cover, CFM oil filler breather, and the Damond can/tubing, it looks completely factory.
Not even so much as an aftermarket battery hold down.
WHY I went with the ST 200 box as well, as Dialcaliper suggested above.
I did go with a CP-E resonated exhaust on the factory downpipe, since I want/need to hear the engine to be able to shift correctly with my sh*t hearing.
But even that system is not too obnoxious (to me at least), so only a bit more 'give away' than the factory system.
Burlington, NC, USA
I’d think you’ll want to at least drill some holes in the lower portion of the airbox to get enough air flow, but otherwise sounds like a great plan. Too far gone now, but wish what’s what I had done.
pelotonracer2
pelotonracer2
NRH
Thank you for your replies.
Only parts purchased for this car so far is hyper black ROTA Titans (probably the last set of hyper black 17x8 4x108 40 offset in the U.S., 215/40-17 Direzza Zllls and a coilover set up. Car is sitting too low for my liking and rides like sh*t but I'm not complaining.
Windows need tinting. I'm going to have to go over this car with caution as it already has a serious drop with lowering springs and an aftermarket radiator. It may also already have an upgraded intercooler, I just can't tell.
I have a huge order in my cart with Ron @ Whoosh.
Burlington, NC, USA
Post some pics or videos. We’ll tell you what we see. Biggest risk is if there are different injectors. The XDI fuel pump would be somewhat obvious if that has been done.
pelotonracer2
pelotonracer2
NRH
It runs like stock. I would think bigger injectors and or a HPFP would make it not run so well. I'm more afraid that it has a tune with an AP that isnt unmarried.
I sold my Explorer ST to CarMax and it has a 93 map. 😬
I couldn't go back to stock because it has an XDI pump.
san diego
This is basically what I did. X37 turbo, turbo smart bov and a MAP intercooler we're the major mods. Kept the stock cat exhaust and intake. Suspension is also stock. I love it. Kind of a sleeper build. I want to be fast I just don't want people to know I'm fast.
san diego
Savage man hopefully whoever buys it uses 93 or kaboom.
Utrecht
Hey guys, next i hope next month all the parts and s280 hybrid turbo will arrived. I saw this tread and i also want a sleeping car that is fast but not too loud. So i ordered the minimum parts with the S280 turbo like;
- upgraded intercooler
- BOV plumb Back
- New Spark Plugs
And i already have RMM and air intake system installed, but want to keep the exhaust systeem all stock for now.
Now i am still deciding if i want to upgrade the exhaust manifold to a turbular manifold from airtec, because the tuner said this won't have extra installation cost. But this airtec manifold is like €750 or something, damm!
Do you guys think the stock manifold will be able to handle this s280 turbo with hopefully over 300hp?
Utrecht
Thanks man, guess i will stick with the atock manifold for now, since i am not planning to go above 400+ hp anytime soon.
Maryland
Yeah, if ur going whoosh you won’t have to worry about hitting that mark. 😁
I was planning to go whoosh, but a great deal come up on an S280 I couldn’t refuse. Hope it doesn’t change the character too much from the zippy fun factor.
Utrecht
Nice man, so how do you like the S280 turbo so far? Any problems that comes after installing this turbo or is it good all around? I was also thinking of installing a lsd if the power is too much to put on the ground haha. So maybe i should save money on that for now.
The coin which you were considering to spend on the Airtec tubular manifold you can put towards a limited slip diff. [wink] [thumb]
Maryland
I don't have the S280 yet, I'm going to pick it up Sunday and hopefully install it next weekend with 30% Injectors.
Maryland
Go S280. Everyone says it and now I know why. The jump from stock to this and the spool is not that different. Less than I though it would be, and I'm just on the base E30 tune. It does have less below 2500 rpm, but to me it seem negligible and I'm a huge fan of stock spool. But the pull is steady and doesn't stop. Can't wait to start running some real boost and timing.
Install took me about 6 hours. I was a bit ham fisted when switching the manifold to the new turbo and broke a stud off inside the turbine housing. I had to use some left handed drill bits to get it out. That added about an hour + to the job. My heat shield bolts were a pain and I struggled with the return line because I left it on the pan and bolted it with new gasket onto the bottom of the turbo once the turbo was installed. I also took the time to remove the nuts from all of the studs that come out of the head as one piece. I then reinstall all the studs back into the head. I really took my time and have zero leaks so far.
