Possibly not, if you run mostly smooth courses with mild to non-existent compressions/dips/jumps.
But, all of those are almost 25" tall, which is way out of range to not expect any rubbing at all.![Frown [:(] [:(]](/images/smilies/frown.png)
The Cooper Evolution Winters seem to have the most 'open block' rally tire-like tread pattern of the lot, and they are XL rated, which generally means at least a slightly stronger side wall than the standard load rated donuts.![Wink [wink] [wink]](/images/smilies/wink.gif)
It looks like 205/50-16, and 195/55-16 winter tires do not exist, but at least three 195/50-16s do.
For winter tires, I’m running a set of Continental TS870’s in that size (195/55-16) and at stock ride height, I have not had any rubbing issues with 16x6.5 et38 rims that put the outer tire face right where the factory wheel/tires sit. The only thing I had to do was trim and put low profile nuts on my mountune mudflaps in the front.
