New 1.6L shortblock with the strenghtened 1.5L deck
United Kingdom
Much cheaper alternative than having the block modified to be closed deck. I suspect these will be much more reliable at high power. Who wants to take one for the team and see? ๐Ÿ˜
SteveS
Osage Beach, MO, USA
The last cars to use the 1.6 Ecoboost were the Fiesta ST and the C-Max in 2019. It seems odd that there was a different block than what came on the 2019 cars at all. Unless it was a running design change planned for the 2020 models and the plug got pulled after a small number had been made or something like that.
Durham, NC, USA
It looks like this block was a revision for a recall Ford did for the 2017-2019 1.5L I4 Escapes (and potentially other models). Specifically, Customer Satisfaction Program 21N12. From some basic digging, I'm having a hard time finding the part number for the revised block, though it also just may not be able for direct sale.
D
Deleted member 21349
Guest
is the the same exact block with just a different cylinder wall design?
D
Guest
From what I've been reading, yes. The Escape uses different rods and pistons so the displacement is smaller, but the bore should be the same as our 1.6 blocks.
ive seen people look into the 1.5l blocks before and they said the thermostat location or coolant hose location is different, cant remember where i read this though...
D
Guest
emailed pumaspeed and they said that short block they are selling is a direct fit for a mk7 st, even confirmed with them that it requries 0 modification to work...
so i bought it, i guess well see how it goes
daloonie
none
Awesome, then we will truely see what this block is. Remember to post the part number stamped on it.
gtx3076
US
How much shipped?
