Fiesta Titanium Auto dimming mirror
XanRules
Portland
Pin #1 Power.
Pin #4 Ground.
Pin #9 Reverse.
Power and ground is in the Map Light Consol.
Reverse power can come from the backup lights.
Run a wire from the mirror across the head liner and down the left "A" pillar.
Run that wire all the way to under the left door sill, you can easily find and connect the wire there.
Dave
Finishing my necro-bump. I ended up grabbing the aforementioned auto-dimming mirror and wiring harness from the junkyard for five whole dollars and another member was kind enough to share the pin-out diagram for the map light console, but I'm curious as to where the reverse light wire is under the door sill. Do you happen to remember or have that information handy? Thanks!
U.S. Navy Veteran
SFV, So.Cal.
I am sorry but I do not remember and over the years some minor changes have been made.
My suggestion would be to remove a taillight and using a test light or multimeter, determine the color of the reverse light wire.
Then locate that wire under the door sill and tap into it.
XanRules
Portland
Cool, I have a rear-view camera that needs to go in, too, so I'll probably just do those at the same time since it'll involve tapping into and testing the same wire. Thanks!
