Critique my upgrade path
Atlanta
I have a bit of money to spend and want to finish upgrading my car. As far as my use case, it's my daily and I don't take it on the track. My philosophy for modding the car is OEM+, and I'm more interested in performance than aesthetics. Aside from regular enthusiastic street driving, I take her on spirited mountain runs when scheduling allows. My wife and toddler-aged daughter are sometimes in the car with me so I'd like for the ride to be a bit more compliant, and I'm not opposed to a small drop either so long as the suspension geometry remains intact. The car absolutely rips with the LSD and Dizzy tune so I want more braking power to balance it too.
This is what I have done already:
  • AP with Dizzy Stage 2 (93 octane)
  • Whoosh V1 intercooler
  • ST200 airbox
  • MFactory LSD
  • Konig Dekagrams
    • 205/45/16 Continental Extreme Contact DWS06+
  • Pedal spacer
Now, onto my planned mods:
Anything I'm missing? For those of you that have a similar OEM+ philosophy for your car, would you do anything differently? Bilstein's B14 coilover kit is a popular choice, but I don't want or need the adjustability since this is my daily, and I'd really prefer to just "set and forget" my suspension. Also, I know Whoosh offers the Wilwood Rear BBK too, but I can't justify a nearly $1k difference for only 18mm in rotor size (Wilwood rear kit is 298mm vs Pumaspeed's 280mm).
Let me know your thoughts.
Grsemky
U.S. Navy Veteran
Arizona
I wouldn't worry about brakes unless your really into tracking it... Modern brakes have more than enough force to lock up a wheel, that's why abs is a thing. Bigger brakes resist fade and manage heat better but that's it
Tires and brake pads will make the biggest difference, upgraded radiator is a no brainer!
Good point on the brake kits, and that would save me a ton of money...
Yes, for your useage a BBK setup is more for aesthetics than anything else.
(But I do not blame you, since they do look GREAT behind some nice wheels!)
How horrid are the roads around your parts?
If really bombed out, I would possibly forgo any FRONT, adjustable camber plates, unless you meant Ron's REAR hub camber plates?? [dunno]
I seriously talk myself out of a BBK almost every month... I do have a thread bookmarked that details taking the brembos from a Renault megane and the rotors from a svt focus...
Those Megane brakes are probably getting more scarce by the day, but a great way to put a top quality big setup on our rides. [thumb]
our guile
Atlanta
The BBKs do look good, but if they're overkill for a street car I'll spend the money on new pads, blanks, and some Endless RBF-600 fluid instead.
I'm in Atlanta, so some areas have smooth roads and others are just a step above some back country off-road trail haha
And yes I meant Ron's rear hub camber plates.
our guile
Atlanta
You don't need the brakes... just use motorcraft S pads. only downside about them is that they dust like crazy (at least for me)
Those are what I've been running since I bought the car new and they do a great job. I just figured with the added power and traction from my current mods it was time for more stopping power too. But fresh pads, rotors, and fluid should be good enough
